Asus GeForce GTX 460 768MB PCI-Express 2.0 HDMI
Quicklinx: 7403WS00 Mfr#: ENGTX460 DIRECTCU TOP/2DI/768M
  • High-Definition Multimedia Interface (HDMI)
  • ASUS Exclusive Voltage Tweak Technology for up to 50% performance
  • ASUS Exclusive DirectCU Thermal Solution: Two 8mm flattened copper heat-pipes to contact GPU directly for up to 20% COOLER than generic GeForce GTX460.
  • Graphics Engine GeForce GTX460
  • Bus Standard PCI Express® 2.0
  • Video Memory 768MB GDDR5
  • Engine Clock 700 MHz
  • CUDA Core Clock 1400MHz
  • Memory Clock 3680MHz (920MHz GDDR5)
  • Memory Interface 192bit
  • DVI Max. Resolution 2560 * 1600
  • DSub Max. Resolution 2048 * 1536
  • DVI Output 2x Native Dual-link DVI-I
  • HDMI Output 1x Native HDMI (Mini HDMI)
  • D-Sub Output 1x via adapter
  • HDCP compliant YES
  • Software Bundled ASUS Utilities & Driver
  • Note The card size is 9.46" x 4.73" inch
Graphics Processor
NVIDIA GeForce GTX 460
Memory Size
768 MB
PCI Express 2.0
Digital Output
Core Clock
700 MHz
Resources
The following resources are available for the Asus GeForce GTX 460 768MB PCI-Express 2.0 HDMI
