Asus GeForce GTX 1080 Ti TURBO 11GB GDDR5X PCIe3.0 Graphics Card
Quicklinx: CV6TWS00 Mfr#: TURBO-GTX1080TI-11G
  • High-Definition Multimedia Interface (HDMI)
  • DisplayPort
ASUS TURBO GeForce GTX 1080 Ti comes equipped with a dual ball-bearing fan for a longer card lifespan and exclusive Auto-Extreme technology with Super Alloy Power II components for superior stability. Customizable backlit logo enables a system personalization and VR-friendly HDMI ports let gamers easily enjoy immersive virtual reality experiences.
  • Dual-ball bearing fan
    The dual-ball bearing fan on ASUS TURBO GeForce GTX 1080 Ti lasts longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency.
  • Auto-Extreme technology with Super Alloy Power II
    ASUS graphics cards are produced, using Auto-Extreme technology, an automated production process, and feature premium Super Alloy Power II components, that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
  • VR-friendly HDMI ports
    ASUS TURBO GeForce GTX 1080 Ti graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime, without having to swap cables.
  • Customizable backlit logo
    ASUS TURBO GeForce GTX 1080 Ti comes with an LED backlit ASUS logo, that you can swap with your own custom design for a truly unique look.
ASUS TURBO-GTX1080TI-11G - graphics card - GF GTX 1080 Ti - 11 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1080 Ti - up to
11 GB GDDR5X
Core Clock
1480 MHz
Boost Clock
1582 MHz
CUDA Cores
3584
Effective Memory Clock
11.01 GHz
Memory Interface
352-bit
Max Resolution
7680 x 4320
Interfaces Details
2 x HDMI , 2 x DisplayPort
API Supported
OpenGL 4.5
3.81 cm x 26.67 cm x 11.12 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1480 MHz
Boost Clock
1582 MHz
CUDA Cores
3584
VR Ready
Max Resolution
7680 x 4320
Interfaces Details
API Supported
OpenGL 4.5
Native HDMI, Nvidia SLI ready, Dual ball Bearing Fan, NVIDIA G-Sync ready, GPU Tweak Streaming, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, HDCP
Size
11 GB
GDDR5X SDRAM
Effective Clock Speed
11.01 GHz
Bus Width
352-bit
Additional Requirements
6-pin + 8-pin PCI Express power connectors
Software Included
Display drivers, XSplit Gamecaster (1 year Premium licence), ASUS GPU Tweak II
3.81 cm
26.67 cm
11.12 cm
