Asus GeForce GT710 2GB GDDR5 PCIe 2.0 DVI D-Sub
Quicklinx: DC1RWS00 Mfr#: GT710-SL-2GD5
ASUS GT 710 is the fantastic graphics card engineered with a highly-efficient 0 dB thermal design, it dissipates heat in complete silence and makes ASUS GT 710 the perfect choice for your PC build. While industry only Auto-Extreme Technology, 100% full automation for premium quality and best reliability. GPU Tweak II provides intuitive performance tweaking for truly elite gaming experience.
Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers.
All ASUS graphics cards are now produced using AUTO-EXTREME technology, an industry-first, 100% automated production process that incorporates premium materials to set a standard of quality. AUTO-EXTREME technology ensures consistent graphics card quality as well as improved performance and longevity. This manufacturing process is also environmentally friendly, eliminating harsh chemicals and reducing power consumption by 50%.
ASUS GT710-SL-2GD5 - graphics card - GF GT 710 - 2 GB
Graphics card
Bus Type
PCI Express 2.0
Graphics Engine
NVIDIA GeForce GT 710 - up to
2 GB GDDR5
Core Clock
954 MHz
CUDA Cores
192
Effective Memory Clock
5012 MHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Interfaces Details
DVI-D , VGA , HDMI
API Supported
DirectX 12
Fanless
1.7 cm x 16.7 cm x 6.9 cm
Graphics card - fanless
Bus Type
PCI Express 2.0
Graphics Engine
Core Clock
954 MHz
CUDA Cores
192
Max Resolution
2560 x 1600
Interfaces Details
DVI-D , VGA , HDMI
API Supported
DirectX 12
Native HDMI, ASUS 0-dB thermal solution, Nvidia PhysX-Ready, NVIDIA Adaptive Vertical Sync, GPU Tweak Streaming, AUTO-EXTREME technology, HDCP
Size
2 GB
GDDR5 SDRAM
Effective Clock Speed
5012 MHz
Bus Width
64-bit
Software Included
Display drivers, ASUS GPU Tweak II
1.7 cm
16.7 cm
6.9 cm
