Asus GeForce GT 730 2GB PCI-E 2.0 HDMI Silent with LP Brackets
Quicklinx: 9K61WS00 Mfr#: GT730-SL-2GD3-BRK
  • High-Definition Multimedia Interface (HDMI)
ASUS GT 730 silent and low profile graphics card with DirectX®11 and HDMI support
  • Silent passive cooling means true 0dB - perfect for quiet home theater PCs and multimedia centers.
  • Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference.
  • GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
  • GPU Tweak Streaming share on-screen action in real time - so others can watch live as games are played.
  • Graphics Engine: NVIDIA GeForce GT 730
  • Bus Standard: PCI Express 2.0
  • Video Memory: GDDR3 2GB
  • Engine Clock: 902 MHz
  • CUDA Core: 384
  • Memory Clock: 900 MHz ( 1800 MHz GDDR3 )
  • Memory Interface: 64-bit
  • Resolution: DVI Max Resolution : 2560x1600
  • Interface: D-Sub Output : Yes x 1 , DVI Output : Yes x 1 (DVI-D), HDMI Output : Yes x 1 , HDCP Support : Yes
  • Software: ASUS GPU Tweak & Driver
  • Dimensions: 5.4 " x 2.71 " x 1.18 " Inch / 13.7 x 6.9 x3 Centimeter
  • Graphics galore for everyone!
    GT 730 is the fantastic graphics card from ASUS. Engineered with a highly-efficient 0dB thermal design, it dissipates heat in complete silence - making GT 730 the perfect choice for your slimline home-theater PC build. Advanced EMI shielding reduces electromagnetic interference for a stable signal, pin-sharp images and safer and healthier computing.
  • Perfect for building a hushed HTPC
    Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers.
  • Enhanced durability and cooling
    Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation.
  • Stream online instantly
    GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
ASUS GT730-SL-2GD3-BRK - graphics card - GF GT 730 - 2 GB
Graphics card - low profile
Bus Type
PCI Express 2.0
Graphics Engine
NVIDIA GeForce GT 730 - up to
2 GB DDR3
Core Clock
902 MHz
CUDA Cores
384
Effective Memory Clock
1.8 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Interfaces Details
DVI-D , VGA , HDMI
API Supported
DirectX 11
Fanless
3 cm x 13.7 cm x 6.9 cm
Microsoft Certification
Compatible with Windows 7
Graphics card - low profile - fanless
Bus Type
PCI Express 2.0
Graphics Engine
Core Clock
902 MHz
CUDA Cores
384
Max Resolution
2560 x 1600
Interfaces Details
DVI-D , VGA , HDMI
API Supported
DirectX 11
Native HDMI, ASUS 0-dB thermal solution, Nvidia PhysX-Ready, Super Alloy Power technology, NVIDIA Adaptive Vertical Sync, GPU Tweak Streaming, HDCP
Size
2 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
64-bit
Software Included
Drivers & Utilities, ASUS GPU Tweak
3 cm
13.7 cm
6.9 cm
