Passive 0dB efficient cooling
DirectCU Silent cooling design utilizes direct contact copper heatpipes and a large heatsink surface to speed up heat dissipation without any noise produced - achieving16% cooler performance than conventional passive cards.Super Alloy Power -
Enhanced durability and cooling
Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
- ASUS GT620-DCSL-2GD3 - graphics card - GF GT 620 - 2 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce GT 620
- Memory
- 2 GB DDR3
- Core Clock
- 700 MHz
- CUDA Cores
- 96
- Effective Memory Clock
- 1.82 GHz
- Shader Clock
- 1400 MHz
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 2560 x 1600 / VGA: 2048 x 1536
- DVI-I (dual link) , VGA , HDMI
- API Supported
- DirectX 11
- Fanless
- 1.52 cm x 18.79 cm x 11.17 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card - fanless
- Bus Type
- Graphics Engine
- Core Clock
- 700 MHz
- CUDA Cores
- 96
- Shader Clock
- 1400 MHz
- Max Resolution
- 2560 x 1600
- API Supported
- DirectX 11
- ASUS 0-dB thermal solution, heatpipe cooling, Nvidia CUDA technology, Nvidia PhysX-Ready, Super Alloy Power technology, ASUS DirectCU Silent Technology, HDCP
- Size
- 2 GB
- Technology
- DDR3 SDRAM
- Effective Clock Speed
- 1.82 GHz
- Bus Width
- 64-bit
- 75 Watt
- Software Included
- ASUS GPU Tweak
- 1.52 cm
- 18.79 cm
- 11.17 cm
