ASUS Phoenix GeForce® GT 1030 OC edition 2GB GDDR5 is the best for compact PC build and home entertainment
- 1531 MHz Boost Clock in OC mode for outstanding performance and gaming experience.
- Dual-ball Bearing Fan reduces spinning friction for 2 times longer lifespan and cooling efficiency.
- IP5X-Certified Fan is dust resistant for longer fan lifespan.
- Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
- GPU Tweak II makes performance tweaking easier and more visual than ever with an intuitive, all-new UI.
Dust resistance
ASUS fan design is dust resistant for improved reliability and optimal fan performance, even under severe conditions. -
Longer lifespan
Without the problem of oil drying common in sleeve-bearing fans, the dual-ball bearing fan on ASUS GT 1030 lasts longer. With reduced friction, it also runs smoother, further improving card lifespan and cooling efficiency. -
Auto-Extreme technology with Super Alloy Power II
ASUS graphics cards are produced using Auto-Extreme technology, an automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
- ASUS PH-GT1030-O2G - OC Edition - graphics card - GF GT 1030 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GT 1030 - up to
- Memory
- 2 GB GDDR5
- Core Clock
- 1278 MHz
- Boost Clock
- 1531 MHz
- CUDA Cores
- 384
- Effective Memory Clock
- 6.008 GHz
- Memory Interface
- 64-bit
- Max Resolution
- 1920 x 1200
- Interfaces Details
- DVI-D (dual link) , HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 3.6 cm x 18.4 cm x 11.1 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1278 MHz
- Boost Clock
- 1531 MHz
- CUDA Cores
- 384
- Max Resolution
- 1920 x 1200
- API Supported
- Nvidia PhysX-Ready, Adaptive V-Sync, Dual ball Bearing Fan, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.008 GHz
- Bus Width
- 64-bit
- Software Included
- Display drivers, ASUS GPU Tweak II
- IP5X
- 3.6 cm
- 18.4 cm
- 11.1 cm
