The ASUS Dual GeForce RTX 4070 SUPER EVO 12GB video card is a powerhouse for gamers and creative professionals alike. With 12 GB of GDDR6X memory, a 192-bit bus width, and a memory speed of 21 Gbps, it delivers performance for 4K gaming and demanding applications. The card supports OpenGL 4.6 and comes with advanced features including 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, and NVIDIA DLSS 3, ensuring lifelike visuals and fluid gameplay. It's HDCP 2.3 compliant and supports up to 4 monitors, making it perfect for multi-display setups. The included 16-pin to 2x 8-pin cable adapter and a thank you card add a touch of appreciation for choosing ASUS. Whether you're battling in titles, creating stunning 3D renders, or streaming content, the ASUS Dual GeForce RTX 4070 SUPER EVO 12GB is engineered to meet expectations.
Enhanced cooling
The ASUS Dual GeForce RTX 4070 SUPER EVO 12GB features an advanced 2.5-slot Fan Cooler, Axial-tech Fan Design, and AUTO-EXTREME technology, ensuring your video card remains cool under heavy load for reliable performance and longevity. -
Superior visuals
Equipped with NVIDIA GeForce RTX 4070 SUPER graphics processor and 12 GB of GDDR6X SDRAM, this video card delivers stunning visuals, smooth frame rates, and detailed graphics at resolutions up to 7680 x 4320. Experience gaming with 3rd gen Ray Tracing Cores and 4th gen Tensor Cores for real-time ray tracing and AI-enhanced graphics. -
Next-gen gaming features
With NVIDIA DLSS 3, NVIDIA Reflex, and support for up to 4 monitors, the ASUS Dual GeForce RTX 4070 SUPER EVO 12GB is designed for a comprehensive gaming experience. Enjoy reduced latency, improved responsiveness, and breathtaking image clarity, making every game more immersive and competitive.
- ASUS Dual GeForce RTX 4070 SUPER EVO 12GB - graphics card - GeForce RTX 4070 Super - 12 GB
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- NVIDIA GeForce RTX 4070 SUPER
- Memory
- 12 GB GDDR6X
- Memory Speed
- 21 Gbps
- Core Clock
- 2475 MHz
- Boost Clock (OC)
- 2505 MHz
- CUDA Cores
- 7168
- Memory Interface
- 192-bit
- Max Resolution
- 7680 x 4320
- Max Monitors Supported
- 4
- Interfaces Details
- HDMI , 3 x DisplayPort
- API Supported
- OpenGL 4.6
- 4.96 cm x 22.72 cm x 12.324 cm
- Graphics card
- Bus Type
- PCI Express 4.0
- Graphics Engine
- Core Clock
- 2475 MHz
- Boost Clock (OC)
- 2505 MHz
- CUDA Cores
- 7168
- VR Ready
- Max Resolution
- 7680 x 4320
- 4
- API Supported
- OpenGL 4.6
- Dual Fan Design, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, Axial-tech Fan Design, NVIDIA DLSS 3, 2.5-slot Fan Cooler, 0dB Technology, Dual ball Bearing Fans, NVIDIA Reflex, NVIDIA RTX Video Super Resolution, Nvidia Studio, Dual Bios, AUTO-EXTREME technology, NVIDIA Ada Lovelace GPU technology, stainless steel mounting bracket, vented backplate, anti-bending plate, 144-hour Validation Programme, Optical Flow Accelerator, Resizable BAR, NVIDIA G-Sync ready, HDCP
- Size
- 12 GB
- Technology
- GDDR6X SDRAM
- Memory Speed
- 21 Gbps
- Bus Width
- 192-bit
- Required Power Supply
- 750 W
- Additional Requirements
- 16 pin PCI Express power connector
- Included Accessories
- Thank you card, 16-pin to 2x 8-pin cable adapter
- Software Included
- ASUS GPU Tweak III, ASUS Quantumcloud, Adobe Creative Cloud (1 month membership), NVIDIA GeForce Experience
- DisplayPort 1.4a, HDCP 2.3
- 4.96 cm
- 22.72 cm
- 12.324 cm
