ASUS Dual GeForce RTX 4070 SUPER 12GB White OC Edition Graphics Card
Quicklinx: HVGKWS00 Mfr#: DUAL-RTX4070S-O12G-WHITE
ASUS Dual GeForce RTX 4070 SUPER fuses dynamic thermal performance with broad compatibility. Advanced cooling solutions from flagship graphics cards - including two Axial-tech fans for maximizing airflow to the heatsink - are packed into the 26.7 cm long, 2.56-slot card, delivering more power in less space. These enhancements make ASUS Dual the perfect choice for gamers who want heavyweight graphics performance in a compact build.
  • Axial-tech fan design
    Two tried-and-true Axial-tech fans feature a smaller hub that facilitates longer blades and a barrier ring to increase downward air pressure.
  • 0dB technology
    To eliminate unnecessary noise, a stop mode halts all fans when the GPU temp falls below 50 degrees and power consumption is low.
  • Dual ball fan bearings
    Different bearing types have unique pros and cons. Ball bearings excel at durability and can last up to twice as long as sleeve bearing designs.
  • 2.56-slot design
    A carefully designed shroud, heatsink, and heatpipe layout allows the two Axial-tech fans to leverage chassis side-panel ventilation and deliver thermal performance that belies the card's size.
  • Dual BIOS
    Do you prioritize low core temps or low noise levels? Performance mode will let the fans spin up to keep the card running cool all the time. Quiet mode keeps the same power target and top-end settings, but offers a less aggressive fan curve for quieter operation at medium temps.
  • Auto-Extreme Technology
    Auto-Extreme Technology is an automated manufacturing process that sets new standards in the industry by allowing all soldering to be completed in a single pass. This reduces thermal strain on components and avoids the use of harsh cleaning chemicals, resulting in less environmental impact, lower manufacturing power consumption, and a more reliable product overall.
  • Protective backplate
    The PCB is reinforced by an aluminum backplate that adds structural rigidity, helping to prevent flex and protect components and trace pathways from damage. The rear features a wide vent that allows hot air to escape towards chassis exhaust fans instead of being recycled back into the GPU cooler.
  • Stainless steel bracket
    The mounting bracket of the Dual has been beefed up with 304 stainless steel that's harder and more resistant to corrosion.
  • 144-hour validation program
    A 144-hour validation program puts cards through a series of stringent tests to ensure compatibility with the latest games.
ASUS Dual GeForce RTX 4070 SUPER 12GB - White OC Edition - graphics card - GeForce RTX 4070 Super - 12 GB - white
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4070 SUPER
12 GB GDDR6X
Memory Speed
21 Gbps
Core Clock
2520 MHz
Boost Clock (OC)
2550 MHz
CUDA Cores
7168
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
HDMI , 3 x DisplayPort
API Supported
OpenGL 4.6
5.113 cm x 26.701 cm x 13.394 cm
Enclosure Colour
White
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Core Clock
2520 MHz
Boost Clock (OC)
2550 MHz
CUDA Cores
7168
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
Dual Fan Design, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, Axial-tech Fan Design, NVIDIA DLSS 3, 2.56-slot Fan Cooler, 0dB Technology, Dual ball Bearing Fans, AUTO-EXTREME technology, NVIDIA Ada Lovelace GPU technology, Nvidia Broadcast, Nvidia Studio, NVIDIA Reflex, Dual Bios, aluminium backplate, stainless steel mounting bracket, 144-hour Validation Programme, Optical Flow Accelerator, NVIDIA RTX Video Super Resolution, NVIDIA G-Sync ready, Resizable BAR, HDCP
Size
12 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
192-bit
Required Power Supply
750 W
Additional Requirements
16 pin PCI Express power connector
Collection card, thank you card, 16-pin to 2x 8-pin cable adapter
Software Included
ASUS GPU Tweak III, GeForce Game Ready Drivers, NVIDIA Studio drivers, Adobe Creative Cloud (1 month membership)
DisplayPort 1.4a, HDCP 2.3
5.113 cm
26.701 cm
13.394 cm
Enclosure Colour
White
