Asus DSL-N10 B1 Wireless N150 ADSL Modem Router
Quicklinx: 8DQ4WS00 Mfr#: DSL-N10 B1
  • IEEE 802.11n
The ASUS DSL-N10 B1 is a true 2-in-1 device, serving as a wired and wireless modem router and a stand-alone router. It combines all the functionality of both device classes, and adds to it with a range of features, including a powerful wide network coverage with the help of 5dBi antenna, four multiple SSIDs, plug-and-connect easy setup, and simple bandwidth prioritization
Plug-n-Surf Installation
3 steps is all you need to setup the router.
Powerful and wide coverage
Featuring 5dBi high-gain antenna, the DSL-N10 B1 provides a boosted signal extended wireless networking range.
Graphic-oriented User Interface
Icon-based user interface displays the entire network status and facilitates advanced settings such as internet security in few clicks.
Bandwidth allocation and access control
The DSL-N10 B1 can provide up to four wireless networks
Ethernet WAN
Ethernet WAN enables DSL-N10 B1 to work in two different scenarios. DSL-N10 B1 allows user to use it as an ADSL modem router or a stand-alone wireless router.
  • Powerful and wide coverage
    Featuring 5 dBi high-gain antenna, the DSL-N10 B1 provides a boosted signal extended wireless networking range.
  • Graphic-oriented user interface
    Icon-based user interface displays the entire network status and facilitates advanced settings such as Internet security in few clicks.
  • Bandwidth allocation and access control
    The DSL-N10 B1 can provides up to four wireless networks.
  • Ethernet WAN
Header / Product Line
ASUS
Wireless router
Connection Type
ADSL (BT)
Header / Model
DSL-N10 B1
Networking / Compliant Standards
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Speed
150 Mbps
Miscellaneous / Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-Enterprise, WPA-PSK, WPA2-Enterprise, WPA2-PSK
Networking / Connectivity Technology
Wired, Wireless
Aerial / Antenna Qty
1
Header / Packaged Quantity
1
Networking / WAN Ports Qty
1
Networking / Frequency Band
2.4 GHz
Networking / Integrated Switch
4-port switch
Aerial / Gain Level
5 dBi
Networking / Form Factor (FE)
Desktop
Standards
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Rackmount or External
External
Aerial / Aerial Form Factor (F)
External detachable
Networking / Remote Management Protocol
HTTP
Aerial / Directivity
Omni-directional
Header / Compatibility
PC
Dimensions & Weight / Height
29mm
Dimensions & Weight / Width
190mm
Dimensions & Weight / Depth
124mm
Dimensions & Weight / Weight
280 g
Environmental Parameters / Min Operating Temperature
-10 °C
Environmental Parameters / Max Operating Temperature
50 °C
Miscellaneous / Compliant Standards
C-Tick, CE, FCC
