Asus 27" ROG Swift PG278Q 27" G-Sync 144Hz Gaming Widescreen LED
FORGED FOR GAMING PERFECTION: THE WORLD'S FIRST WQHD G-SYNC MONITOR!!!
Quicklinx: 9LGBWS00 Mfr#: PG278Q
Quite possibly the best gaming monitor ever made and ideally suited to NVIDIA cards with 3D Vision 2.0 and G-Sync technology. This monitor runs at a staggoring 2560x1440 resolution with 144Hz technology and a 1ms response, even better this is the latest in TN technology.
- Display: 27-inch (16:9) wide screen
- Resolution: 2560 × 1440 WQHD with 1ms response rate.
- 144Hz max refresh rate for fast gaming.
- Brightness: 350cd/m²
- Connectivity: DisplayPort, USB 3.0 ports (upstream x 1, downstream × 2)
- Ergonomic Tilt (+20° ~ -5°), swivel (+60° ~ -60°), pivot (90° clockwise), height adjustment (0 ~ 120mm)
- VESA wall mountable (100 × 100mm)
- ASUS Exclusive
- ASUS GamePlus
- 5-way menu controller,
- Minimum bezel, Maximum ROG design!
- Narrow 6mm bezel designed for multi-monitor setups
- Pixel Pitch: 0.233mm
- Display Colors: 16.7M
- Refresh Rate: Over 120 Hz
- Response Time: 1ms (GTG)
- Special ASUS Features: GamePlus and 5-way joystick OSD navigation
Experience Immersive Gaming and Outstanding Visuals
Say goodbye to motion blur and lag with 120+ Hz refresh rate and 1ms response times for a competitive advantage in all your games thanks to smoother gameplay and on-screen responsiveness. The ROG SWIFT PG278Q also features GamePlus, an exclusive ASUS feature. GamePlus is an OSD overlay that enables crosshair and timer functions to be displayed on the monitor. Gamers can select from four different crosshair types to suit the gaming environment, while the timer function allows players to track elapsed time in real-time strategy games. These tools allow gamers to practice and improve their gaming skills. The ROG SWIFT PG278Q provides an array of options that include DisplayPort 1.2 for native WQHD output, dual USB 3.0 ports, VESA wall mount capability and a versatile stand with full tilt, swivel, pivot, and height adjustment for an ideal viewing position while playing the latest game title. The smart cable management feature rids your desktop of tangled wires, while the super narrow 6mm bezel ensures the ROG SWIFT PG278Q is an ideal choice for seamless multi-display gaming setups. Another nod to gamers and improving the user experience is a 5-way joystick that allows the user to easily navigate the OSD and make quick monitor adjustments. The World's First and Fastest WQHD Monitor powered by NVIDIA G-SYNC The ROG SWIFT PG278Q is also the world's first WQHD monitor powered by NVIDIA® G-SYNC™ technology. NVIDIA® G-SYNC™, a breakthrough in display technology, synchronizes the display's refresh rates to the GPU. The ROG SWIFT PG278Q eliminates screen tearing, minimizes stutter and input lag to deliver the smoothest gaming experience possible. With G-SYNC™ technology objects look sharper and more vibrant, while gameplay is more fluid and responsive.
ASUS ROG SWIFT PG278Q - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
64 kWh
Power Consumption (On mode)
44 W
USB 3.0 hub
Native Resolution
QHD 2560 x 1440 at 144 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Gaming
Colour Support
16.7 million colours
Input Connectors
DisplayPort
Display Position Adjustments
61.97 cm x 6.598 cm x 36.296 cm
7 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark, J-MOSS, ErP Ready, CEL level 1
3-year warranty
Display Type
Energy Class
Class C
64 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 144 Hz
Horizontal Refresh Rate
89 - 222 kHz
Gaming
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), Light-in-Motion LED, nVidia 3D Vision 2 Ready, Active Shutter 3D technology, 5-way Navigation Key, ASUS GamePlus, nVidia 3D Vision, NVIDIA Ultra Low Motion Blur Technology, ASUS Refresh Rate Turbo Key, ASUS Smart Air Vent Design
61.97 cm x 6.598 cm x 36.296 cm - with stand
7 kg
DisplayPort , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable
Power Supply
External
44 W
Power Consumption (Typical)
90 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
