Ascom D62 Talker (Basic)
Quicklinx: BKDDWS00 Mfr#: DH4-ACAA
For convenient hands-free use, Ascom headsets offer a choice of an integrated or boom microphone or their robust headset with hearing protection for noisy environments.
  • Adapt your handset to your needs
    The d62 handset is the ideal solution, when effective communication can have a direct effect on safety, health or security. This means, that the capability of the d62 can be easily adapted, as your requirements change or grow.
  • Advanced messaging interaction
    The messaging capability of the d62 makes it ideal for applications, such as integration with nurse call or patient monitoring. A call from a patient terminal can be sent directly to the handset, indicating the type of call and location of the patient. The nurse can speak directly to the patient or acknowledge a message with a push of a button. If the nurse is unavailable, the call is automatically rerouted to another nurse. Messages can also be prioritized in two ways - by presenting them according to priority in the message list or by color coding.
  • Smoother upgrades and reduced downtime
    Centralized management allows for smooth, trouble-free software upgrades and parameter synchronizations. The individual settings on each handset are stored centrally. With an IP-DECT system, administration of end-user devices can be easily facilitated over the air (OTA). Both systems offer great advantages in terms of flexibility and cost efficiency.
Ascom d62 Talker - cordless extension handset with caller ID
Cordless extension handset with caller ID
Total Number of Wireless Handsets
1
Cordless Phone Standard
IP-DECT\GAP
Speakerphone
Call Services
Voice Mail, Caller ID
Display
LCD display - colour - Yes
1
Phone Features
IP-DECT\GAP
Call Services
Caller ID Type
Caller ID
Dialer Location
Handset
Speakerphone
Messaging Services
SMS
Phone Memory
Phone Directory Capacity
250 names & numbers
Caller ID Memory
25 names & numbers
Display
Display Location
Handset
Display Resolution
128 x 160 pixels
Colour Depth
16-bit (65000 colours)
Backlit
Headset jack
Belt clip
Rechargeable - Lithium Ion
Talk Time
Up to 1200 min
Standby Time
Up to 240 h
Recharge Time
4 hour(s)
Dimensions & Weight (Handset)
5.3 cm
2.6 cm
13.4 cm
130 g
