The HP Smart Array P410 is HP's PCI Express 2.0 (PCIe) Serial Attached SCSI (SAS) RAID controller. The low profile, half height card has 8 ports and utilizes DDR2-800 memory. The P410 is ideal for RAID 0/1, 1 0, 5 0 and can be upgraded with the 512MB battery-backed write cache (BBWC) module and Smart Array Advanced via license key for RAID 6 &, 6 0.
- HPE Smart Array P410/256MB Controller - storage controller (RAID) - SATA 1.5Gb/s / SAS - PCIe x8
- Storage controller (RAID) - plug-in card - low profile
- Bus Type
- PCIe x8
- Interface
- Data Transfer Rate
- 3 Gbit/s
- Buffer Size
- 256 MB
- Supported Devices
- Hard drive, disk array (RAID)
- Max Storage Devices Qty
- 64
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, RAID 50
- 5.7 cm x 24.1 cm x 19.1 cm
- Designed For
- ProLiant DL120 G7, DL160 G6, DL160se G6, DL165 G6, DL165 G7, DL170h G6, DL180 G6, DL2x170h G6, DL320 G6, DL370 G6, DL380 G6, DL380 G7, DL385 G6, DL385 G7, DL4x170h G6, DL580 G7, DL585 G6, DL585 G7, DL785 G6, ML110 G7, ML330 G6, SL160z G6, SL165s G7, SL165z G6, SL165z G7, SL170z G6, SL2x170z G6
- Host Bus
- PCIe x8
Storage Controller
- Interface
- 3 Gbit/s
- Buffer Size
- 256 MB
- Supported Devices
- 64
- RAID Level
- 2 x SATA 1.5Gb/s / SAS - 36 pin 4i Mini MultiLane (internal)
- Compatible Slots
- 1 x PCI Express x8
- 5.7 cm
- 24.1 cm
- 19.1 cm
- Designed For
- HPE ProLiant DL120 G7, DL120 G7 Base, DL120 G7 Entry, DL120 G7 Performance, DL160 G6, DL160 G6 Special Server, DL160se G6, DL165 G6, DL165 G7, DL165 G7 Base, DL165 G7 Entry, DL165 G7 Performance, DL165 G7 Special Server, DL170h G6, DL180 G6, DL180 G6 Special Server, DL185 G5, DL185 G5 Special Server, DL2x170h G6, DL320 G6, DL320 G6 Entry, DL320 G6 High Efficiency, DL320 G6 Performance, DL360 G6, DL360 G6 Base, DL360 G6 Efficiency, DL360 G6 Entry, DL360 G6 Performance, DL365 G5, DL365 G5 Base, DL365 G5 Entry, DL365 G5 High Efficiency, DL365 G5 Performance, DL370 G6, DL370 G6 Base, DL370 G6 High Performance, DL370 G6 Performance, DL380 G6, DL380 G6 Base, DL380 G6 Entry, DL380 G6 High Efficiency, DL380 G6 Performance, DL380 G7, DL380 G7 Base, DL380 G7 Entry, DL380 G7 Performance, DL380 G7 Special Server, DL385 G5p, DL385 G5p Base, DL385 G5p Entry, DL385 G5p High Performance, DL385 G6, DL385 G6 Base, DL385 G6 Entry, DL385 G6 High Performance, DL385 G7, DL385 G7 Base, DL385 G7 Entry, DL385 G7 HE, DL385 G7 Performance, DL4x170h G6, DL580 G5, DL580 G5 Base, DL580 G5 High Performance, DL580 G7, DL580 G7 Base, DL580 G7 High Performance, DL585 G5, DL585 G5 High Performance, DL585 G6, DL585 G6 Base, DL585 G6 Performance, DL585 G7, DL585 G7 Base, DL585 G7 Performance, DL785 G5, DL785 G6, DL785 G6 Base, DL785 G6 Performance, ML110 G7, ML110 G7 Base, ML110 G7 Entry, ML110 G7 Performance, ML150 G6, ML150 G6 Base, ML150 G6 Entry, ML150 G6 Performance, ML310 G5, ML310 G5p, ML330 G6, ML330 G6 Base, ML330 G6 Entry, ML350 G6, ML350 G6 Base, ML350 G6 Entry, ML350 G6 Performance, ML370 G6, ML370 G6 Base, ML370 G6 Entry, SL160z G6, SL165s G7, SL165z G6, SL165z G7, SL170z G6, SL2x170z G6
