Aruba Instant On AP12 (RW) Access Point
Quicklinx: FBK2WS00 Mfr#: R2X01A
  • IEEE 802.11n
The Aruba Instant ON delivers high-performance, secure Wi-Fi for small businesses.
  • Eliminates High Cost of Cabling with Full-scale Wireless Mesh Coverage
    HPE Aruba Networking Instant On AP12 Indoor Access Points have built-in wireless mesh capabilities to cost-effectively extend Wi-Fi connectivity without additional cables.Conveniently expands your network to hard-to-wire areas – nearly getting rid of spotty connections and dead zones, to provide Wi-Fi where you need it.
  • Safeguard Sensitive Data with WPA2/WPA3 and Enhanced Open
    HPE Aruba Networking Instant On AP12 Indoor Access Points come with integrated Wi-Fi Alliance security standard WPA2/WPA3 and Enhanced Open support for protected wireless access.Create up to eight different SSIDs under one network name to keep your data safe, whether surfing the web or checking HR data.
  • Simplicity is the Key to a Great Wi-Fi Experience
    The HPE Aruba Networking Instant On AP12 Indoor Access Points are built with premium hardware and software quality that's as reliable and coming from a trusted vendor.Effortless set-up right out of the box – in the palm of your hand.The HPE Aruba Networking Instant On portfolio comes with flexible management options to choose from: The HPE Aruba Networking Instant On mobile app guides you through step-by-step from initial set-up to ongoing management.Ideal for small and growing businesses like cafés, retail stores or professional offices, and other Wi-Fi hotspots.Simple to build landing page lets you customize your guest access page with your logo, your own brand, and acceptance of use language.
HPE Networking Instant On AP12 (RW) - radio access point - Bluetooth, Wi-Fi 5
Radio access point
External - indoor
Bluetooth, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Ceiling rail mount clip, solid surface mount clip
Power Over Ethernet (PoE) Supported
PoE
15.7 cm x 15.7 cm x 3.4 cm
483 g
Radio access point
Ruggedized Design
Indoor
15.7 cm
15.7 cm
3.4 cm
483 g
External
Wireless
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Status, reset
Reset button, Aruba Beacons Bluetooth Low-Energy (BLE) technology, 3x3:3 MU-MIMO technology, security slot (Kensington security lock compatible), mobile app and cloud portal, Smart Mesh technology
Encryption Algorithm
WPA2, WPA3
IEEE 802.3af, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
Directivity
Omni-directional
1 x Ethernet 1000 (uplink, PoE) , 1 x USB
1 x network cable
MTBF
1,116,000 hour(s)
UL 2043, EN 60601-1-2, EN 60601-1-1
PoE
Limited warranty - 2 years , Technical support - phone consulting - 90 days , Product info support - web support - 2 years
50 °C
5 - 93% (non-condensing)
