Aruba AP-335 NBase-T Access Point, 802.11n/ac, 4x4 MU-MIMO, dual radio, integrated antennas
Quicklinx: C7HWWS00 Mfr#: AP-335
  • IEEE 802.11n
The Aruba 330 series access points provide fast Gigabit data speeds and superb user experience for mobile devices and applications in a digital workplace. The 330 series allows enterprises to leverage their multi-gigabit Ethernet wired network infrastructures to eliminate bottlenecks. The 330 series APs deliver amazing 802.11ac Wi-Fi infrastructure that is ideal for lecture halls, auditoriums, public venues, and high-density office environments. The high-performance and high-density 802.11ac 330 series APs support 4-stream multi-user MIMO and 4 spatial streams. They provide simultaneous multicast data transmission to multiple devices, maximizing data throughput and improving network efficiency.
HPE Aruba AP 335 - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
DC 48 V
22.5 cm x 22.4 cm x 5.2 cm
1.15 kg
Radio access point
22.5 cm
22.4 cm
5.2 cm
1.15 kg
External
Wireless
Data Transfer Rate
1733 Mbps
Line Coding Format
CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
System, status
Auto-uplink (auto MDI/MDI-X), DFS support, reset button, Maximum Ratio Combining (MRC), Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Energy Efficient Ethernet, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), Advanced Cellular Coexistence (ACC), cyclic shift diversity (CSD), Aruba Beacons Bluetooth Low-Energy (BLE) technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
12
Directivity
Omni-directional
1 x 1000Base-T - RJ-45 , 1 x 2500Base-T - RJ-45 , 1 x USB 2.0 - Type A , 1 x console - RJ-45
MTBF
531,662 hours
EN 60950, IEC 60950, UL 60950, CB, UL 2043, FCC, EN 60601-1-2, cTUVus, EN 300 328, EN 301 489, EN 60601-1-1, LVD 72/23/EEC, R&TTE Directive 1999/5/EC, EN 301 893
PoE
DC 48 V
25 Watt
Limited warranty - lifetime
50 °C
5 - 95% (non-condensing)
