Aruba AP 334 Radio Access Point
Quicklinx: C7HTWS00 Mfr#: AP-334
  • IEEE 802.11n
The Aruba 330 Series access points provide the fastest gigabit data speeds and superb user experience for mobile devices and applications in a digital workplace. Designed with an integrated HPE Smart Rate port to scale up to 2.5Gbps Ethernet over existing copper, the 330 Series allows enterprises to leverage their multi-gigabit Ethernet wired network infrastructures to eliminate bottlenecks. These Wave 2 access points deliver multi-user MIMO (MU-MIMO) aware ClientMatch to boost network efficiency and support the growing device density demands on your network.
  • Multi-gig Ethernet
    Leverage wired multi-gig NBASE-T -compatible Ethernet infrastructure to eliminate bottlenecks in high-density environments.
  • ClientMatch unleashes MU-MIMO
    Aruba ClientMatch software groups Wave 2 clients together, enabling 4x4:4SS MU-MIMO. That means a faster, more efficient network.
  • Integrated Bluetooth Beacon
    330 series APs have an integrated BLE Beacon to simplify management of a large-scale network of battery-powered Aruba Beacons.
HPE Aruba AP 334 - radio access point - Wi-Fi 5
Radio access point
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Power Over Ethernet (PoE) Supported
PoE
DC 48 V
22.5 cm x 22.4 cm x 5.2 cm
1.15 kg
Radio access point
22.5 cm
22.4 cm
5.2 cm
1.15 kg
External
Wireless
Data Transfer Rate
1733 Mbps
Line Coding Format
CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
System, status
Auto-uplink (auto MDI/MDI-X), DFS support, reset button, Maximum Ratio Combining (MRC), Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Energy Efficient Ethernet, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), Advanced Cellular Coexistence (ACC), cyclic shift diversity (CSD), Aruba Beacons Bluetooth Low-Energy (BLE) technology
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
1 x 1000Base-T - RJ-45 , 1 x 2500Base-T - RJ-45 , 1 x USB 2.0 - Type A , 1 x console - RJ-45 , 4 x aerial - RP-SMA
MTBF
531,662 hours
EN 60950, IEC 60950, UL 60950, CB, UL 2043, FCC, EN 60601-1-2, cTUVus, EN 300 328, EN 301 489, EN 60601-1-1, LVD 72/23/EEC, R&TTE Directive 1999/5/EC, EN 301 893
PoE
DC 48 V
25 Watt
Limited warranty - lifetime
50 °C
5 - 95% (non-condensing)
