The Aruba 310 series access points deliver high performance and superb user experience for mobile devices, Internet of Things (IoT) devices, and applications in dense office environments. Featuring the 4x4:4SS MU-MIMO capability, advanced Aruba ClientMatch radio management, and Aruba Beacon technologies, the 310 series enables an all-wireless digital work environment in a cost-effective manner.
Dual Radio 802.11ac access point with multi-user MIMO
Supports up to 1,733Mbps in the 5GHz band (with 4SS/VHT80 or 2SS/VHT160 clients) and up to 400 Mbps in the 2.4 GHz band (with 2SS/VHT40 clients). -
Built-in Bluetooth Low-Energy (BLE) radio
Enables location based services with BLE-enabled mobile devices receiving signals from multiple Aruba Beacons at the same time. -
Advanced Cellular Coexistence (ACC)
Minimizes interference from 3G/4G cellular networks, distributed antenna systems, and commercial small cell/femtocell equipment. -
Quality of service for unified communication apps
Supports priority handling and policy enforcement for unified communication apps.
- HPE Aruba AP 315 - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Wireless clients: 255 , BSSIDs per radio: 16
- Power Over Ethernet (PoE) Supported
- PoE
- 18.2 cm x 18 cm x 4.8 cm
- 650 g
- Limited lifetime warranty
- 18.2 cm
- 18 cm
- 4.8 cm
- 650 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1.733 Mbps
- Line Coding Format
- CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
- Spread Spectrum Method
- OFDM, DSSS
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Auto-sensing per device, auto-uplink (auto MDI/MDI-X), DFS support, Quality of Service (QoS), Adaptive Radio Management (ARM), Maximum Ratio Combining (MRC), Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Cyclic Delay Diversity (CDD), Advanced Cellular Coexistence (ACC), cyclic shift diversity (CSD), MU-MIMO technology, Aruba Beacons Bluetooth Low-Energy (BLE) technology
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- Directivity
- Omni-directional
- 1 x 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
- MTBF
- 916,373 hours
- EN 60950, IEC 60950, UL 60950, CB, UL 2043, FCC, R&TTE, EN 60601-1-2, cTUVus, EN 300 328, EN 301 489, EN 60601-1-1, LVD 72/23/EEC, EN 301 893
- PoE
- 14.4 Watt
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 5 - 95% (non-condensing)
