The HPE 525 802.11ac Dual Radio Access Points Series supports two spatial streams offering 867 Mbps performance, faster application processing, and increased range to 802.11 clients. Ideal for dense client environments and high-bandwidth applications, the series can be powered by PoE and offers full compatibility with legacy 802.11 clients and existing HPE wireless controllers. The series works with HPE Unified Wireless LAN Controllers to provide automatic detection, classification, and intelligent mitigation of non-IEEE 802.11 interference and comprehensive threat protection.
Optimized Performance for Rich Media and BYOD
The HPE 525 802.11ac Dual Radio Access Point Series delivers the latest in Wi-Fi technology, offering up to 867 Mbps in the 5 GHz frequency band and up to 300 Mbps in the 2.4 GHz band for high-bandwidth applications and BYOD.Supports both centralized and distributed traffic forwarding for unparalleled application performance and WLAN scalability.It provides advanced quality of service (QoS) for voice and video communications with support for rate limiting and IEEE 802.1p traffic prioritization and Spectralink Voice Priority (SVP).Extends network availability with self-healing, self-optimizing local mesh. -
Improved Coverage and Reliability
The HPE 525 802.11ac Dual Radio Access Point Series optimizes WLAN coverage and reliability with Wi-Fi Clear Connect automatic power adjustment, real-time identification of interference, and intelligent channel switching.Enhances the user experience with airtime fairness, providing equal RF transmission time for wireless clients in mixed client environments.Improves client performance by automatically redirecting 5 GHz-capable clients to the less-congested 5 GHz spectrum.Provides excellent coverage through use of embedded high-gain antennas and optional external antennas. -
Comprehensive Security
The HPE 525 802.11ac Dual Radio Access Point Series provides comprehensive threat protection with integrated IDS/IPS offering granular threat detection, mitigation and location tracking capabilities.It can simplify client authentication for support of internal and external authentication, authorization and accounting servers (AAA), and per user VLAN mapping and authentication.Locks out unauthorized wireless access by authenticating users prior to granting network access and secure data integrity of the wireless traffic with Advanced Encryption Standard (AES) or Temporal Key Integrity Protocol (TKIP). -
Investment Protection
The HPE 525 802.11ac Dual Radio Access Point Series has a Limited Lifetime Warranty.The series provides interoperability with all IEEE 802.11a/b/g/n/ac client devices through Wi-Fi Alliance certifications.It reduces the need to upgrade to PoE+ by fully powering both radios with 802.11af PoE.
- HPE 525 (WW) - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- In-ceiling - indoor
- Processor
- 1 x 720 MHz
- RAM
- 256 MB
- Flash Memory
- 128 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- Maximum number of configured SSIDs: 16
- Included Accessories
- 2 x ceiling mounting clip
- Power Over Ethernet (PoE) Supported
- PoE
- 22 cm x 22 cm x 6 cm
- 750 g
- Limited lifetime warranty
- Ruggedized Design
- Indoor
- 22 cm
- 22 cm
- 6 cm
- 750 g
Processor / Memory / Storage
- Processors Installed
- 1 x 720 MHz
- RAM
- 256 MB SDRAM
- Flash Memory
- 128 MB
- Form Factor
- In-ceiling
- Connectivity Technology
- Wireless
- DHCP
- Remote Management Protocol
- SNMP 3, SNMP 2c
- Frequency Band
- 2.4 GHz, 5 GHz
- Capacity
- MIMO technology, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), plenum-rated, Wi-Fi Clear Connect
- Encryption Algorithm
- MD5, SSL, TLS, PEAP, TTLS, TKIP, WPA, WPA2, WEP
- Authentication Method
- RADIUS, PAP, CHAP, MS-CHAP v.2, Extensible Authentication Protocol (EAP), EAP-FAST
- IEEE 802.11, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.1i, IEEE 802.11a, IEEE 802.3af, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- External detachable and internal
- Antenna Qty
- 8
- Directivity
- Omni-directional
- 1 x 1000Base-T (PoE) - RJ-45 , 1 x 1000Base-T - RJ-45 , 1 x management - RJ-45 , 4 x aerial - RP-SMA
- EN55022 Class B, ICES-003 Class B, FCC Part 15 B, FCC Part 15.247, OET 65 C, RSS-210, RSS-102, UL 2043, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, FCC Part 15.407, EN 60601-1-2, ARIB STD-T66, ARIB STD-T71, RCR STD-33, iDA, EN 300 328, EN 301 489-1, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- PoE
- Limited warranty - advance parts replacement - lifetime - response time: next business day
- 0 °C
- 45 °C
- 5 - 95% (non-condensing)
