Your basket is empty
Aruba 215 Instant 802.11ac (WW) Access Point
Quicklinx: BGMDWS00 Mfr#: JL186A
Type: Radio access point
Connectivity: Wireless
Speed: 1.3Gbps
Protocol: IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
£220.74 ex VAT
£264.88 inc VAT
These compact and cost-effective dual-radio APs deliver wireless data rates of up to 1.3 Gbps to 5-GHz devices with 802.11ac technology. They also support 3 x 3 MIMO with three spatial streams as well as 2.4-GHz 802.11n clients at data rates up to 450 Mbps. IAP-215 features six integrated omni-directional downtilt antennas.
HPE 215 Instant (WW) - radio access point
Radio access point
External - indoor
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
Mounting brackets
Power Over Ethernet (PoE) Supported
PoE
18 cm x 18 cm x 4.5 cm
610 g
Radio access point
Ruggedized Design
Indoor
18 cm
18 cm
4.5 cm
610 g
External
Wireless
Data Transfer Rate
1.3 Gbps
Line Coding Format
CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM, DSSS
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Link activity, power, status, wireless
Auto-sensing per device, auto-uplink (auto MDI/MDI-X), DFS support, reset button, Adaptive Radio Management (ARM), Maximum Ratio Combining (MRC), 3T3R MIMO technology, Low Density Parity Check (LDPC), Transmit Beam-forming (TxBF) ready, Energy Efficient Ethernet, Cyclic Delay Diversity (CDD), Space Time Blocking Code (STBC), security lock slot (cable lock sold separately), Advanced Cellular Coexistence (ACC), cyclic shift diversity (CSD)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at, IEEE 802.3az, IEEE 802.11ac
Aerial
Antenna
Internal
Antenna Qty
6
Directivity
Omni-directional
1 x 1000Base-T (PoE) - RJ-45 , 1 x USB 2.0 - Type A , 1 x console - RJ-45
Mounting brackets
MTBF
538,975 hours
EN 60950, IEC 60950, IEC 60601-1-1, IEC 60601-1-2, UL 60950, CB, EN 300.328, Directive 1999/5/EC, IC, UL 2043, FCC, R&TTE, EN 301.893, EN 60601-1-2, cTUVus, FIPS, LVD, Directive 2006/95/EC, EN 301 489
PoE
50 °C
5 - 95% (non-condensing)
BGMD C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.26
BGMD C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
BGMD C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.42
BGMD C2G 2m Cat6a Shielded Patch - Blue In Stock £7.44
BGMD C2G TruLink Media Gateway RJ45 Cap In Stock £0.58
BGMD C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £47.13
Speed: 1.3Gbps
Compatibility: PC
Brand: Aruba
Price Range Ex VAT: 150 - 300
