Enhanced connectivity
The HPE Aruba SFP+ transceiver module offers a high-speed 10 Gigabit Ethernet connection that ensures rapid data transfer rates of up to 10 Gbps, making it suitable for high-bandwidth applications. -
Broad compatibility
Featuring an LC multi-mode connector, this transceiver module is designed to facilitate seamless integration with a wide range of networking equipment, ensuring a flexible solution for your connectivity needs. -
Extended reach
With a maximum transfer distance of 300 m, the HPE Aruba SFP+ transceiver module is perfect for extending your network reach, making it suitable for a variety of enterprise environments.
- HPE Aruba - SFP+ transceiver module - 10GbE
- SFP+ transceiver module - SFP+ / LC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR
- Data Transfer Rate
- 10 Gbps
- Data Link Protocol
- 10GbE
- Max Transfer Distance
- 300 m
- Designed For
- HPE Aruba 2540 24, 2540 48, 2930F 12, 2930F 48, 2930F 8G, 2930M 24, 2930M 40, 2930M 48, 3810M 24, 3810M 48, 5406R 16, 5406R 44, 5406R 8-port, 5406R zl2, 5412R 92, 5412R zl2, 54XX, 6200F 12, 6200M 24, 6300, 6405 48, 6405 96, 64XX, 70XX, 72XX, 83XX, 8400, 8400 8-slot; CX 8360; Instant On 1930 48
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GBase-SR
- 10GbE
- 10 Gbps
- 300 m
- 1 x Ethernet 10GBase-SR - LC multi-mode
- OM3
- Designed For
- HPE Aruba 2930F 12G PoE+ 2G/2SFP+, 2930F 8G PoE+ 2SFP+ TAA, 2930M 24 Smart Rate POE+ 1-Slot, 2930M 24G 1-Slot, 2930M 24G POE+ 1-Slot, 2930M 40G 8 HPE Smart Rate PoE Class 6 1-slot Switch, 2930M 40G 8 HPE Smart Rate PoE+ 1-slot Switch, 2930M 48G 1-Slot, 2930M 48G POE+ 1-Slot, 3810M 24SFP+ 250W, 3810M 48G PoE+ 4SFP+ 1050W, 3810M 48G PoE+ 4SFP+ 680W, 6200F 12G Class4 PoE 2G/2SFP+ 139W Switch, 6200F 12G Class4 PoE 2G/2SFP+ 139W TAA Switch, 6200M 24G Class4 PoE 4SFP+, 6300F, 6300M, 6405 48SFP+ 8SFP56, 6405 96G CL4 PoE 4SFP56, 6405 Switch Bundle, 6410, 6410 Switch Bundle, 7005 (IL) FIPS/TAA-compliant Controller, 7005 (JP) Controller, 7005 (JP) FIPS/TAA Controller, 7005 (RW) FIPS/TAA-compliant Controller, 7005 (US) FIPS/TAA Controller, 7005 Cloud Service Controller, 7010 (IL) Controller, 7010 (JP) FIPS/TAA Controller, 7010 (RW) FIPS/TAA-compliant Controller, 7024 (JP) FIPS/TAA Controller, 7024 (RW) FIPS/TAA-compliant Controller, 7024 (US) Controller, 7024 (US) FIPS/TAA Controller, 7030 (JP) FIPS/TAA Controller, 7030 (RW) FIPS/TAA-compliant Controller, 7030 (US), 7030 (US) FIPS/TAA Controller, 7205 (IL) FIPS/TAA-compliant Controller, 7205 (JP) Controller, 7205 (JP) FIPS/TAA Controller, 7205 (RW) FIPS/TAA-compliant Controller, 7205 (US), 7205 (US) Controller, 7205 (US) FIPS/TAA Controller, 7210 (JP) FIPS/TAA Controller, 7210 (RW) FIPS/TAA-compliant Controller, 7210 (US), 7210DC (JP) Controller, 7210DC (US) Controller, 7220 (JP) Controller, 7220 (RW) FIPS/TAA-compliant Controller, 7220 (US) FIPS/TAA Controller, 7220DC (IL) Mobility Controller, 7240 (RW) FIPS/TAA-compliant Controller, 7240 (US) FIPS/TAA Controller, 7240XM (IL) FIPS Controller, 7240XM (JP) FIPS/TAA Controller, 7240XM (RW) FIPS Controller, 7240XM (US) FIPS Controller, 8320, 8325-32C, 8325-48Y8C, 8400 8-slot Chassis, 8400 Management Module , HPE Aruba CX 8360-12C V2, 8360-16Y2C V2 , HPE Aruba Instant On 1930 48G Class4 PoE 4SFP/SFP+ 370W Switch
