Arctic Cooling Freezer 13 CPU Cooler (Intel & AMD Compatibility)
REDUCED TO CLEAR!
Quicklinx: 7H0RWS00 Mfr#: UCACO-FZ130-BL
Freezer 13 carries on the legacy of the renowned Freezer 7 Pro Rev.2 to continue providing efficient and low noise CPU cooling solution for enthusiasts. Featuring four U-shaped high performance heatpipes and 45 efficiently formed aluminum fins; the Freezer 13 is able to dissipate massive heat that is produced in high-end CPUs, such as Intel Core i7.
ARCTIC Freezer 13 - 200W CPU Cooler for Intel socket 1366 / 1156 / 1155 / 1150 / 775 + AMD socket FM2 / FM2+ / FM1 / AM3+ / AM3 / AM2+ / AM2 / 939 / 754
ARCTIC Freezer 13 - processor cooler
Processor cooler
Compatibility
LGA775 Socket, Socket 939, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket, Socket AM1, LGA1151 Socket, Socket AM4, LGA2066 Socket
Heatsink Material
Aluminium
Fan Diameter
92 mm
Fan Bearing
Fluid dynamic bearing
Rotation Speed
600-2000 rpm
Air Flow
36.4 cfm
Heat pipe technology, Pulse-width modulation (PWM) support
695 g
6-year warranty
Processor cooler
695 g
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Heatsink Dimensions
130 mm x 123 mm x 96 mm
Fan Diameter
92 mm
Fan Bearing
Rotation Speed
600-2000 rpm
Air Flow
36.4 cfm
Limited warranty: - 6 years
