Arctic Cooling Alpine 64 GT CPU Cooler for AMD FM2 / FM2+ / FM1 / AM3+ / AM3 / AM2+ / AM2 / 939/754
Quicklinx: 7NW3WS00 Mfr#: UCACO-P1600-GBA01
Alpine 64 GT is a cooler designed for AMD CPU, offering a cost-effective and ultra quiet solution for system builders and distributors.
ARCTIC Alpine64 GT Rev.2 - 75W CPU Cooler for AMD socket FM2 / FM2+ / FM1 / AM3+ / AM3 / AM2+ / AM2 / 939 / 754
  • High price-performance ratio
    Unlike other low cost coolers, the cost-effective Alpine 64 GT comes with high quality components, making it a complete thermal and noise management solution. The pre-applied high performance thermal compound MX-2, an optimized heat sink and an 80mm fan provide satisfactory cooling performance. The Alpine 64 GT is extremely quiet, generating only 0.3 sone of noise compared with 0.8 sone from a standard cooler. Moreover, with the PWM function, the fan runs just at the necessary speed, resulting in lowest noise level possible at sufficient cooling capacity. Together with the low noise impeller and the patented fan holder, noise level can be kept minimal at all time.
  • Easy installation
    With the user-friendly design, the Alpine 64 GT can be installed within minutes. Remove the standard cooler, place the Alpine 64 GT on the CPU, lock two lugs with the retention module, and you are ready to enjoy the quietness brought by this cooler.
Arctic Cooling Alpine 64 GT - processor cooler
Processor cooler
Compatibility
Socket 754, Socket 939, Socket AM2, Socket AM2+, Socket AM3
Fan Diameter
80 mm
Fan Bearing
Fluid dynamic bearing
Rotation Speed
500-2000 rpm
Air Flow
24.6 cfm
Pulse-width modulation (PWM) support
8.4 cm x 10 cm x 6.5 cm
295 g
6 years warranty
Processor cooler
8.4 cm
10 cm
6.5 cm
295 g
Heatsink & Fan
Compatible With
Fan Diameter
80 mm
Fan Bearing
Rotation Speed
500-2000 rpm
Air Flow
24.6 cfm
6 years warranty
Service & Support Details
Limited warranty - 6 years
