Because it's made from a custom high-performance fluoroelastomer, the Sport Band is durable and strong, yet surprisingly soft. The smooth, dense material drapes elegantly across your wrist and feels comfortable next to your skin. An innovative pin-and-tuck closure ensures a clean fit.
- Apple USB-C to USB Adapter - USB-C adapter - USB Type A to 24 pin USB-C
- USB-C adapter
- Sync and charge
- Connector
- 9 pin USB Type A - female
- Connector (Second End)
- 24 pin USB-C - male
- Designed For
- 10.9-inch iPad Air (4th generation); 11-inch iPad Pro; 12.9-inch iPad Pro; iMac; iMac Pro (Late 2017); iPad mini (6th generation); Mac mini (Early 2020, Late 2018, Late 2020); Mac Pro (Late 2019); MacBook (Early 2015, Early 2016, Mid 2017); MacBook Air; MacBook Pro
- USB-C adapter
- Sync and charge
- Connector
- Designed For
- Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation) , Apple iMac (Early 2019, Early 2021, Mid 2017, Mid 2020) , Apple iMac Pro (Late 2017) , Apple iPad mini (6th generation) , Apple Mac mini (Early 2020, Late 2018, Late 2020) , Apple Mac Pro (Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2020, Late 2018, Late 2020, Mid 2019) , Apple MacBook Pro (Early 2020, Late 2016, Late 2019, Late 2020, Mid 2017, Mid 2018, Mid 2019)
