Apple 12.9-inch iPad Pro Wi-Fi 128GB - Silver
CONTACT OUR IT SPECIALISTS TO ENQUIRE ABOUT EDUCATION PRICING!
Quicklinx: G93WWS00 Mfr#: MHNG3B/A
Marketing description is not available.
  • M2 chip
    M2 turbocharges machine learning with a faster Neural Engine and has extra memory-ordinary power that brings unprecedented performance and capabilities to the iPad Pro. You'll be able to create ultra-realistic 3D designs, build complex AR models, and immerse yourself in games with console graphics at even higher frame rates. And even when you throw yourself into such intense activities, you can count on a battery that lasts a full day.
  • Take video production into your own hands
    The M2 chip has a high-performance media engine that speeds up ProRes encoding and decoding-now conversion to this format is faster.
  • XDR Liquid Retina Display
    The Liquid Retina XDR display achieves an extraordinarily realistic level of definition. With excellent contrast, it's ideal for viewing and editing HDR photos and videos, and it's also perfect for enjoying movies and TV series. Its brightness is to die for. It comes standard with advanced technologies such as ProMotion, True Tone and the wide P3 color gamut. Plus you can use it in Reference mode, an essential aid for all jobs that require absolute color accuracy.
  • Zone-based brightness management
    The more than 10,000 mini-LEDs are grouped into more than 2,500 local dimming zones. The brightness of each is carefully adjusted according to what you're seeing, to achieve the incredible level of contrast. This ensures that even the most detailed HDR images and the most spectacular lighting effects, from explosions in action movies to panoramas of stars and galaxies, are rendered extremely accurately.
  • Front-facing camera
    iPad Pro has an ultra-wide-angle front-facing camera with a 12MP sensor and 122° field angle, ideal for taking photos and videos to post on social media. With the Auto Frame feature it always keeps you center stage in FaceTime calls, and there is also Portrait mode for taking beautiful selfies. It also works together with the TrueDepth camera to let you securely unlock your device with Face ID.
  • Automatic framing
    With ultra-wide-angle and machine learning, the Auto Frame feature frees you from your desk during video calls. Move around the room, and the frame will shift so you're never out of view. The lens also narrows the field or widens it as other people join you or leave during the call. And it also works with other developers' video conferencing apps, not just FaceTime. So you'll always be center stage.
  • Ultra-wide-angle
    The LiDAR scanner measures the time it takes light to reach an object and return, creating a depth map of the space you're in and making incredibly immersive AR experiences possible. Plus, it works with the powerful ISP processor to focus images and videos more accurately when there is little light, and reduce capture time.
  • Ultra-fast connections
    With ultrafast Wi-Fi, iPad has always been a champion of portability. And with Wi-Fi, you have the fastest wireless connection-everything goes like clockwork, even when sending large photos, files, and videos.
Apple 12.9-inch iPad Pro Wi-Fi - 5th generation - tablet - 128 GB - 12.9"
Tablet
Display
12.9" IPS Mini LED backlight - 2732 x 2048 (264 ppi) - Multi-Touch
Apple M1 (8-core)
Storage
128 GB
RAM
8 GB
Wireless Connectivity
Bluetooth 5.0, 802.11a/b/g/n/ac/ax
Rear Camera
12 Megapixel focus: automatic
Second Rear Camera
10 Megapixel
Front Camera
12 Megapixel
Security Devices
Face ID
Battery Run Time
Up to 10 hours
21.49 cm x 0.64 cm x 28.06 cm
682 g
Silver
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Tablet
Operating System
Apple iPadOS 15
Display
12.9" IPS - Mini LED backlight
Resolution
Touchscreen
Multi-Touch
Image Brightness
600 cd/m²
Anti-reflective, BFR/PVC-free, Mercury free, beryllium free, arsenic free, fully laminated display, True Tone display, ProMotion technology, 120 Hz refresh rate, HDR10 compatible, fingerprint-resistant oleophobic coating, HLG gamma, Liquid Retina display, P3 Wide Color Gamut, Extreme Dynamic Range (XDR), Apple Pencil (2nd generation) support, Dolby Vision, 2D backlighting system, 1000 cd/m² max full-screen brightness, 1600 cd/m² peak brightness (HDR)
Apple M1
Number of Cores
8-core
Storage
128 GB
RAM
8 GB
Communications
Rear Camera
Sensor Resolution
12 Megapixel
Camera Zoom
2x optical zoom, 5x digital zoom
Focus Adjustment
Automatic
Lens Aperture
F/1.8
Lens Element Qty
5-element
HDR Mode
Smart HDR 3
Camera Modes
Burst mode, Panorama, Time-lapse mode, Slow motion mode, wide colour capture for photos and Live Photos, Wide
Light Source
Brighter True Tone flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1280 x 720 (720p) at 30 fps, Slo-mo video 1920 x 1080 (1080p) at 120 fps, 3840 x 2160 (4K) at 30 fps, 3840 x 2160 (4K) at 60 fps, 3840 x 2160 (4K) at 24 fps, 1920 x 1080 (1080p) at 25 fps, Slo-mo video 1920 x 1080 (1080p) at 240 fps, 3840 x 2160 (4K) at 25 fps
Sapphire crystal lens cover, Cinematic video stabilisation, Focus Pixels, Cinematic video stabilisation, Playback zoom, geotagging, Stereo Recording, Continuous autofocus video, Advanced red-eye correction, Panorama (up to 63MP), Audio zoom, Extended dynamic range for video at 30 fps
Second Rear Camera
Sensor Resolution
10 Megapixel
Lens Aperture
F/2.4
Field of View (FoV)
125 degree(s)
Ultra-wide angle shot, Lens correction
Front Camera
Sensor Resolution
12 Megapixel
Lens Aperture
F/2.4
Field of View (FoV)
122 degree(s)
HDR Mode
Smart HDR 3
Camera Modes
Burst mode, Time-lapse mode, Portrait Lighting, wide colour capture for photos and Live Photos, Portrait, Ultra Wide Mode, Centre Stage
Light Source
Retina Flash
Video Resolutions
1920 x 1080 (1080p) at 30 fps, 1920 x 1080 (1080p) at 60 fps, 1920 x 1080 (1080p) at 25 fps
FaceTime HD camera, Auto image stabilisation, Animoji, Memoji, TrueDepth camera, Cinematic video stabilisation, Extended dynamic range for video at 30 fps, Time-lapse video with stabilisation, Lens correction
Multimedia
Graphics
Apple M1 8-core
Supported Digital Audio Standards
AAC, Audible, MP3, FLAC, Apple Lossless, AC-3, AAC-LC, LPCM, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, HE-AAC v2, Dolby Atmos
Supported Digital Video Standards
H.264, HEVC, MPEG-4 Part 2, Motion JPEG
Audio
5 microphones, four speakers
Input Device
Security Devices
Face ID
Software
Preloaded Software
Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Find My iPhone, Stocks, Siri, Books, Reminders, Music, Find My Friends, Settings, Voice Memos, iTunes Store, Numbers, Pages, Keynote, Podcasts, Apple Pay, Apple TV App, Home, Measure, Tips
System Requirements for PC Connection
Microsoft Windows 7 or later, Apple MacOS X El Capitan 10.11.6 or later
Expansion and Connectivity
1 x Thunderbolt 3/DisplayPort/USB4 , 1 x Smart Connector , 1 x Magnetic connector
Lithium polymer
40.88 Wh
Run Time
Up to 10 hours
Run Time Details
Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s)
Silver
Case Material
Aluminum
Sensors
Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer, LiDAR scanner
AirPlay, Dictation, AssistiveTouch, iBeacon microlocation, Voice Control, Speak Screen, Magnifier, Closed Captions, Switch Control
Power adapter
USB-C charge cable - 1 m
21.49 cm
0.64 cm
28.06 cm
682 g
Sustainability Information
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
35 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
45 °C
Max Altitude Operating
3 km
