The Apple Studio Display combines state-of-the-art digital imaging technology with advanced software-based features unique to Apple. The result is a high-performance flat-panel display that's ideal for anyone who spends a lot of time manipulating text, graphics, and other media on-screen. Whether you're a multimedia content creator, a designer, a writer, an educator, or an accountant, the Apple Studio Display can make your job look a lot better to you-and vice versa. The TFT active-matrix LCD technology used by the Apple Studio Display enables it to offer outstanding brightness, contrast ratio, and sharpness-for optimal viewing. It also provides an impressively wide viewing angle, as well as completely eliminating screen flicker. And the Apple Studio Display offers all of this performance in a product that's a fraction the size of a traditional computer monitor.
Probably the most distinguishing feature of this display, though, is the advantage it takes of Apple's outstanding hardware/software integration. In the case of the Apple Studio Display, this enables an unmatched combination of "smart features" and superior software controls-adding up to an extraordinarily flexible, responsive device with which to view your work. In fact, the Apple Studio Display can make that eight-plus hours per day you spend in front of your computer significantly more productive - and surprisingly more pleasant. If you deal primarily with graphics, you'll be glad to know that the Apple Studio Display requires no special graphics adapter to work seamlessly with your computer. If you deal more with multimedia, you'll appreciate its built-in connectors for composite and S-video as well as audio input. And if what you deal with most frequently is a combination, you'll find the display's ability to shift instantly between graphics and video modes invaluable. The Apple Studio Display-when you look at all of its high-performance capabilities, you'll really like what you see.
- Apple Studio Display Nano-texture glass - LCD monitor - 5K - 27" - with tilt- and height-adjustable stand
- LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/1053323
- Energy Class
- Class E
- 12 megapixel camera, 6 speakers, 3 microphone beam forming array, USB PD 96 Watt
- Native Resolution
- 5K 5120 x 2880
- Brightness
- 600 cd/m²
- Colour Support
- 1 billion colours
- Input Connectors
- Thunderbolt 3
- Audio Input
- 3-microphone array
- Built-in Webcam
- 12 Megapixel (ultra wide)
- Height, tilt
- Voltage
- AC 100-240 V (50/60 Hz)
- 62.3 cm x 20.7 cm x 47.9 cm
- 7.7 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Display Type
- LCD monitor
- Energy Class
- Class E
- Diagonal Size
- 27"
- Built-in Devices
- USB Power Delivery
- 96 Watt
- Native Resolution
- 5K 5120 x 2880
- Pixel Per Inch
- 218
- Brightness
- 600 cd/m²
- Colour Support
- 1 billion colours
- Retina display, P3 Wide Color Gamut, True Tone technology, nano-texture glass, Dolby Atmos
- 7.7 kg
Built-in Webcam
- Sensor Resolution
- 122° field of view, F 2.4 lens aperture, Center Stage
Audio Input
Audio
- Speakers with subwoofer - stereo with subwoofer
- Thunderbolt 3 / USB-C (power up to 96W) , 3 x USB-C
Mechanical
- Height, tilt
- Tilt Angle
- -5/+25
- Height Adjustment
- 105 mm
- Spatial Audio, A13 Bionic chip
- Cables Included
- 1 x Thunderbolt cable - 1 m
- Localisation
- Input Voltage
- Power Consumption SDR (On mode)
- 21.2 kWh/1000h
- Included Software
- Siri
- OS Required
- Apple macOS Monterey 12.3 or later, Apple iPadOS 15.4 or later
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 10 °C
- 35 °C
- 5 - 90% (non-condensing)
