Apple Pro Display XDR 32" 6016x3384 IPS LED Monitor- Standard Glass
Quicklinx: FKXVWS00 Mfr#: MWPE2B/A
The contrast your eyes see between brightness and darkness is very challenging to reproduce in a display, leading to the development of High Dynamic Range (HDR). With breakthrough backlighting technology, Pro Display XDR takes brightness, contrast, and color to the high level. Far beyond HDR, it's Extreme Dynamic Range (XDR).
  • Legal
    ¹Screen size is measured diagonally. ²In temperatures less than 25° C. ³Sold separately.
Apple Pro Display XDR Standard glass - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class G
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
6016 x 3384 at 60 Hz
Brightness
1600 cd/m²
Contrast Ratio
1000000:1
Colour Support
1.074 billion colours (10-bit)
Input Connectors
Thunderbolt 3
Screen Coating
Anti-glare
Voltage
AC 120/230 V (50 - 60 Hz)
71.8 cm x 2.7 cm x 41.2 cm
7.48 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Display Type
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
32"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
218
Brightness
1600 cd/m²
Contrast Ratio
1000000:1
Colour Support
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Aluminum enclosure, BFR/PVC-free, Mercury free, beryllium free, arsenic free, Retina display, fully laminated display, True Tone display, 10-bit Colour Depth, P3 Wide Color Gamut, Extreme Dynamic Range (XDR), dual ambient light sensor
71.8 cm x 2.7 cm x 41.2 cm - without stand
7.48 kg
Thunderbolt 3 / USB-C (power up to 95W) , 3 x USB-C
Cleaning cloth
1 x Thunderbolt 3 cable - 2 m
Input Voltage
49 kWh/1000h
Power Consumption HDR (On mode)
54 kWh/1000h
Sustainability Information
ENERGY STAR Certified
Limited warranty - 1 year , Technical support - phone consulting - 90 days
10 °C
35 °C
5 - 95% (non-condensing)
