Apple iPhone 6s Leather Case - (PRODUCT)RED
Quicklinx: BTB5WS00 Mfr#: MKXX2ZM/A
These Apple-designed cases are made from specially tanned and finished European leather for a luxurious feel and are precision crafted by the same designers who create iPhone. The case fits snugly and your iPhone 6s or iPhone 6 still feels incredibly slim, even with the case on. The soft microfiber lining on the inside helps protect your iPhone. And on the outside, you see color that’s more than surface deep, thanks to a dye that’s infused into the leather.
  • A case worthy of iPhone 5s
    iPhone 5s has a stunning exterior. So any case that dares to conceal it should be equally appealing. The Apple-designed leather cases more than meet the requirement. Made from premium leather, they look and feel luxurious. And because they're precision crafted for iPhone 5s, your phone still feels incredibly slim even with the case on.
  • Precision made, beautifully crafted
    The leather is deliberately shaped to cover the volume buttons, the on/off switch and the chamfered edge of iPhone 5s. Inside, a soft microfiber lining protects the exterior of your iPhone. Outside, you see color that's more than surface deep thanks to a dye that's infused into the leather.
Apple (PRODUCT) RED - back cover for mobile phone
Back cover for mobile phone
Material
Leather
Red
Material
Leather
Lining Material
Microfibre
Red
Carrying Case
Protective cover
Recommended Use
For mobile phone
Cover Type
Back cover
