Apple USB-C to Lightning Adapter
Quicklinx: HF3TWS00 Mfr#: MUQX3ZM/A
Device Type: Apple
Type: Adaptor
Product Range: Apple
Product Model: Lightning Adaptor
£23.86 ex VAT
£28.63 inc VAT
The USB-C to Lightning Adapter lets you connect your Lightning accessories to a USB-C-enabled iPhone or iPad to conveniently provide three key functions — charging, data and audio — with a single adapter. This adapter has a braided cable for added durability.
Plug the USB-C end of the adapter into the USB-C connector on your iPhone or iPad, then connect your Lightning accessory.
This adapter supports connection to most cars, including those that work with CarPlay. You can also directly connect a USB cable from your car into the USB-C connector on your iPhone. Learn more about compatibility options in this article.
  • Durable design
    Featuring a braided cable, this Apple Lightning adapter is designed for enhanced durability and resistance against wear and tear, ensuring a longer lifespan for your essential accessory.
  • Seamless connectivity
    With a male 24-pin USB-C connector on one end and a female Apple Lightning connector on the other, this adapter ensures a seamless connection between your devices, enabling efficient charging and data transfer.
Cable
Lightning adapter
Connector
24 pin USB-C - male
Connector (Second End)
Lightning - female
Braided
1-year warranty
Cable Type
Lightning adapter
Braided
Connector
24 pin USB-C - male
Apple Lightning - female
Limited warranty - 1 year
Device Type: Apple
Type: Adaptor
Brand: Apple
