You have to hold iPad Air to believe it. It's just 7.5 millimetres thin and weighs less than half a kilo. The stunning Retina display sits inside thinner bezels, so all you see is your content. And an incredible amount of power lies inside the sleek enclosure. So you can do so much more. With so much less.
All-better design, leaner, and definitely meaner
iPad Air is impossibly thin but incredibly solid thanks to its aluminum unibody design. It dropped almost a quarter of the volume of the previous-generation iPad. So it weighs just one gravity-defying pound. But what makes iPad Air truly remarkable is that it packs so much more power and capability into its sleek enclosure. So you can do even more with it, while carrying even less with you. -
Retina display, so much to see, so little to hold
iPad has always been about the display. And that's even truer with iPad Air. Because Apple reduced the width of the device, along with the bezels on the sides of the display. But the size of the stunning Retina display is exactly the same. So your content fills your view more than ever. -
Incredible performance, it's light on everything but power
The Apple-designed A7 chip brings 64-bit desktop-class architecture to iPad. That means up to twice the CPU speed and graphics performance for everything you do. And still long hour of battery life to study, play, build, and create whatever you want, all you want. -
A7 chip
The A7 chip takes iPad to heights of power and speed. Thanks to the A7 chip, apps run faster. Games are more responsive. And everything you do with iPad Air feels quicker, because it is quicker. Up to twice as quick, in fact. And the A7 chip features 64-bit architecture, opening the door for even more robust and powerful apps. Which means even more possibilities for what you can do with iPad Air. -
M7 coprocessor
iPad Air was designed to be on the move. That's why the M7 coprocessor makes so much sense. It measures motion from your iPad Air by pulling data from the accelerometer, gyroscope, and compass. So your apps can give you a better experience based on the movement of your iPad Air. It's a task that would normally fall to the A7 chip. But M7 is more efficient at it, which saves on power. -
Same great battery life
iPad Air is powerful, but not power hungry. Even though it's 20 percent thinner and up to twice as fast as the previous-generation iPad, it still gives you the same incredible long-hour battery life. That's because the A7 chip isn't just more powerful, it's also more efficient. So no matter where you go with iPad Air, you'll have the battery power to go even further. -
Ultrafast Wi-Fi
iPad Air gives you up to twice the Wi-Fi performance thanks to two antennas and MIMO (multiple-input multiple-output) technology. With dual-band 802.11n Wi-Fi and MIMO, download speeds can reach up to 300 Mbps - double the data rate of the previous-generation iPad. So now when you want to download a movie, share photos or documents with AirDrop, or just browse the web, your connection is even faster than before.
- Apple iPad Air Wi-Fi - 1st generation - tablet - 16 GB - 9.7"
- Product Type
- Tablet
- Display
- 9.7" IPS TFT - LED backlight - 2048 x 1536 (264 ppi) - Multi-Touch
- Processor
- Apple A7 - 64-bit
- Storage
- 16 GB
- Wireless Connectivity
- 802.11a/b/g/n, Bluetooth 4.0
- Rear Camera
- 5 Megapixel focus: automatic
- Front Camera
- 1.2 Megapixel
- Battery Run Time
- Up to 10 hours
- 16.95 cm x 0.75 cm x 24 cm
- 469 g
- Space grey
- Localisation
- English / United Kingdom
- SAR
- 0.53 W/kg (body)
- 1-year warranty
- Product Type
- Tablet
- Operating System
- Apple iOS 7
Display
- Resolution
- Touchscreen
- Multi-Touch
- Anti-fingerprint, Retina display
- Processor
- Apple A7
- 64-bit Computing
- Storage
- 16 GB
Communications
Rear Camera
- Sensor Resolution
- 5 Megapixel
- Focus Adjustment
- Automatic
- Geotagging
Front Camera
- Sensor Resolution
- 1.2 Megapixel
- FaceTime HD camera
Multimedia
- Supported Digital Audio Standards
- WAV, AAC, AIFF, Audible, MP3, Apple Lossless, protected AAC
- Supported Digital Video Standards
- MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 1080p)
- Audio
- Two microphones, speaker
Software
- Preloaded Software
- Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, FaceTime, Photo Booth, Safari, Videos, Photos, App Store, Maps, Game Center, iBooks, Newsstand, Siri, iCloud, Reminders, Music, iTunes Store
System Requirements for PC Connection
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP Professional SP3, Microsoft Windows XP Home Edition SP3, Apple MacOS X 10.6.8 or later, Windows 8
Expansion and Connectivity
- 1 x headphones , 1 x Lightning
- Technology
- Lithium polymer
- Capacity
- 32.4 Wh
- Run Time
- Up to 10 hours
- Run Time Details
- Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s)
- Space grey
- Sensors
- Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass
- Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, Apple M7 motion coprocessor
- Included Accessories
- Power adapter
- Cables Included
- Lightning to USB cable
- SAR Value
- 0.53 W/kg (body)
- Localisation
- 16.95 cm
- 0.75 cm
- 24 cm
- 469 g
- Limited warranty - 1 year , Technical support - phone consulting - 90 days
- 0 °C
- 35 °C
- 5 - 95% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 45 °C
Apple Lightning Digital AV Adapter | In Stock | £37.49 |
Apple Lightning to USB Camera Adapter | In Stock | £22.32 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £15.49 |
Apple Lightning to USB Cable (0.5m) | In Stock | £15.00 |
Apple Lightning to USB Cable (2 m) | In Stock | £29.17 |
StarTech.com 2x USB Wall Charger 17W / 3.4A | In Stock | £15.56 |
Apple Lightning to SD Card Camera Reader | In Stock | £26.42 |
Apple EarPods with Lightning Connector | In Stock | £14.34 |
Apple Lightning to 3.5 mm Headphone Jack Adapter | In Stock | £7.21 |
Apple Lightning to USB 3 Camera Adapter | In Stock | £25.39 |
Apple AirPods - 2nd Generation | In Stock | £95.83 |
Apple 12W USB Power Adapter | In Stock | £15.23 |
Apple Magic Keyboard - British English | In Stock | £79.51 |
Apple USB-C to Lightning Cable 2m | In Stock | £26.59 |
Apple AirPods (3rd Gen) with Lightning Charging Case | In Stock | £132.50 |
