Product
APC UPS Network Management Card 2
Quicklinx: 64RKWS00 Mfr#: AP9630
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet
Form Factor: Plug-in module
Compatibility: PC
Type: Remote management adapter
More than 50 in stock
£214.66 ex VAT
£257.59 inc VAT
APC UPS network management cards allow for secure monitoring and control of an individual APC UPS via web browser, command line interface, or SNMP. Embedded technology provides exceptional reliability with notification features that inform you of problems as they occur.
  • Command line interface
    Offers simultaneous remote management access through Telnet and SSH
  • Compatible with SmartSlot enabled UPSs
    Compatible with all SmartSlot UPSs
  • IPv6 Support
    Capable of operating on a network using IPv6 protocol
  • Standard UPS RFC 1628 MIB Compatible
    Make UPS information available to your preferred network, server or enterprise management system by forwarding SNMP traps (events) using RFC 1628 MIB
  • Device Encryption
    Securely connect via HTTPS/SSL, SSH (up to 2048-bit encryption), SNMPv3
  • Multiple language support
    Web browser interface available in English, French, Russian, Chinese, Japanese, Korean, German, Italian, Spanish, Portuguese
  • Multiple user access
    Supports simultaneous web browser access for up to 8 users and network command line interface access for up to 3 users
  • UPS Firmware Update
    User friendly mechanism to remotely and seamlessly update UPS firmware via the web browser interface (SMX, SMT and SRT Smart-UPS only)
  • Smart Battery Management Support
    Detailed battery information including battery cartridge parameters provides early-warning fault analysis to simplify management of the entire battery system (SRT Smart-UPS only)
  • Modbus TCP Support
    Supports reporting UPS information to Building Management Systems or other third party management systems via Modbus TCP
  • BACnet/IP Support
    Supports reporting UPS information to Building Management Systems or other third party management systems via BACnet/IP (pending BTL certification) (Single Phase Smart-UPS and Symmetra only)
APC Network Management Card 2 - remote management adapter
Plug-in module
Interface (Bus) Type
SmartSlot
Ports
10/100 Ethernet
12.1 cm x 11.4 cm x 3.8 cm
80 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
2 years warranty
Smart-UPS 1000 LCD, 1500 LCD, 2200 LCD, 3000 LCD, 750 LCD; Smart-UPS RM 3000VA USB & Serial; Smart-UPS X
Plug-in module
SmartSlot
Ports
10/100 Ethernet
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, HTTP, HTTPS, SSH
2048-bit encryption, E-mail alert, firmware upgradable
1 x 100Base-TX - RJ-45
Compatible Slots
1 x SmartSlot
Encryption Algorithm
SSL
FCC Class A certified, GOST, ICES-003, VCCI Class A ITE, EN55024, EN55022 Class A, AS/NZ 3548 Class A, FCC Part 15, RoHS, C-Tick Class A
Software Included
Drivers & Utilities
12.1 cm
11.4 cm
3.8 cm
80 g
-5 °C
45 °C
APC Smart-UPS 1000 LCD, 1500 LCD, 2200 LCD, 3000 LCD, 750 LCD , APC Smart-UPS RM 3000VA USB & Serial , APC Smart-UPS X
Protocol: Ethernet
Protocol: Fast Ethernet
Compatibility: PC
Brand: APC
Price Range Ex VAT: 150 - 300
