APC UPS network management cards allow for secure monitoring and control of an individual APC UPS via web browser, command line interface, or SNMP. Embedded technology provides exceptional reliability with notification features that inform you of problems as they occur.
BACnet/IP Support
Supports reporting UPS information to Building Management Systems or other third party management systems via BACnet/IP (BTL certified) (Single Phase Smart-UPS and Symmetra only). -
Command line interface
Offers simultaneous remote management access through Telnet and SSH -
Compatible with SmartSlot enabled UPSs
Compatible with all SmartSlot UPSs -
Device Encryption
Securely connect via HTTPS/SSL, SSH (up to 2048-bit encryption), SNMPv3 -
IPv6 Support
Capable of operating on a network using IPv6 protocol -
Modbus TCP Support
Supports reporting UPS information to Building Management Systems or other third party management systems via Modbus TCP. -
Multiple language support
Web browser interface available in English, French, Russian, Chinese, Japanese, Korean, German, Italian, Spanish, Portuguese -
Multiple user access
Supports simultaneous web browser access for up to 8 users and network command line interface access for up to 3 users -
Smart Battery Management Support
Detailed battery information including battery cartridge parameters provides early-warning fault analysis to simplify management of the entire battery system (SRT Smart-UPS only). -
Standard UPS RFC 1628 MIB Compatible
Make UPS information available to your preferred network, server or enterprise management system by forwarding SNMP traps (events) using RFC 1628 MIB. -
UPS Firmware Update
User friendly mechanism to remotely and seamlessly update UPS firmware via the web browser interface (SMX, SMT and SRT Smart-UPS only).
- APC Network Management Card 2 - remote management adapter - SmartSlot - 10/100 Ethernet
- Remote management adapter
- Form Factor
- Plug-in module
- Interface (Bus) Type
- SmartSlot
- Ports
- 10/100 Ethernet
- 12.1 cm x 11.4 cm x 3.8 cm
- 80 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX
- Data Link Protocol
- 10Mb LAN, 100Mb LAN
- Data Transfer Rate
- 100 Mbps
- Black
- 2-year warranty
- Designed For
- Smart-UPS X
- Form Factor
- Plug-in module
- SmartSlot
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- Ethernet, Fast Ethernet
- 100 Mbps
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, HTTP, HTTPS, SSH
- 2048-bit encryption, E-mail alert, firmware upgradable
- 1 x 100Base-TX - RJ-45
- Compatible Slots
- 1 x SmartSlot
- Encryption Algorithm
- SSL
- FCC Class A certified, GOST, ICES-003, VCCI Class A ITE, EN55024, EN55022 Class A, AS/NZ 3548 Class A, FCC Part 15, RoHS, C-Tick Class A
- Black
- Software Included
- Drivers & Utilities
- 12.1 cm
- 11.4 cm
- 3.8 cm
- 80 g
- Limited warranty - 2 years
- -5 °C
- 45 °C
- Designed For
- APC Smart-UPS X
APC UPS Network Management Card 2
