APC Smart-UPS XL Modular 48V Extended Run Battery Pack
Quicklinx: 93CKWS00 Mfr#: SUM48RMXLBP2U
APC Smart-UPS XL protects your data by supplying reliable, network-grade power with scalable run-time in tower and rack mount form factors. With optional, matching battery packs, run-time can be easily extended and optimized for the application. APC understands long run-time requirements, so Smart-UPS XLs can be configured with up to 10 additional battery packs - for run-times exceeding 24 hours, if necessary.
APC Smart-UPS XL Modular 48V Extended Run Battery Pack - battery enclosure
Battery enclosure - external
Rack Size
2U
60 kg
Battery Form Factor
Plug-in module
Batteries Qty
2 (installed) / 2 (supported)
43 cm x 67.8 cm x 8.6 cm
P/N: SMT1500RMI2UNC, SMT2200RMI2UNC, SMT30002U-BR, SMT3000RMI2UNC, SMT750RMI2UNC, SMX3000HV-BR, SMX3000LV2U-BR, SMX750INC, SUM1500RMXL2U, SUM1500RMXLI2U, SUM3000RMXL2U, SUM3000RMXL2U-TU, SUM3000RMXLI2U, SURT1000RMXLI-NC, SURT1000XLI-NC
Battery Enclosure Type
Plug-in module
Height (Rack Units)
2U
Quantity
Voltage Provided
48 V
Limited warranty - parts and labour - 2 years
0 - 95%
43 cm
67.8 cm
8.6 cm
60 kg
