APC Smart-UPS SRT UPS  5000 Watt  Lead Acid
Quicklinx: 9N8XWS00 Mfr#: SRT5KRMXLI
Type: Battery
Power Rating: 4500Watt
£4,224.97 ex VAT
£5,069.96 inc VAT
LCD graphics display has text and mimic diagrams that display modes of operation, system parameters and alarms. Connect the device to a network using a 10 or 100 BASE-T connection. Green mode bypasses unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection. Battery failure notification provides early-warning fault analysis on batteries enabling timely preventive maintenance. Automatic internal bypass supplies utility power to the connected loads in the event of a UPS power overload or fault. Scalable runtime allows additional run time to be quickly added as needed. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms
  • ECO Mode
    Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection
  • 10/100 BaseT Connection
    Connect the device to a network using a 10 or 100 BaseT connection
APC Smart-UPS SRT 5000VA RM - UPS - 4500 Watt - 5000 VA
UPS - rack-mountable
Rack Size
3U
54.55 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
4500 Watt / 5000 VA
Input Connectors
Hardwire 3-wire (1PH + N + G)
Output connectors
6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 2 x IEC connector
Lead Acid
Run Time (Up To)
4 min at full load
USB
43.2 cm x 71.9 cm x 13 cm
3-year warranty
P/N: ACDC2513, AR2407, AR2480, AR2487, AR2487G, AR2507, AR2580, AR2587, AR3100G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3300G, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, NBWL0356A
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
4500 Watt / 5000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Efficiency
98%
Lead Acid
Run Time (Up To)
4 min at full load , 11.8 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
USB
1 x serial - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Audible alarm, LCD display
C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
43.2 cm
71.9 cm
13 cm
54.55 kg
Shipping Width
61 cm
Shipping Depth
96 cm
Shipping Height
33 cm
Shipping Weight
63.6 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, ACF001, ACF002, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR2407, AR2480, AR2487, AR2487G, AR2507, AR2580, AR2587, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR8135BLK, NBWL0356A
9N8X APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.59
9N8X APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £48.79
9N8X APC - Power cable - Male-Female - 1.98 m In Stock £50.90
9N8X APC Basic Rack-Mount PDU - power distribution strip In Stock £201.26
9N8X APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.79
9N8X APC Power cable - 2.4 m In Stock £85.98
9N8X APC Rack PDU Basic Zero U 16A 208/230V In Stock £297.66
9N8X APC Temperature and Humidity Sensor In Stock £132.71
9N8X APC POWER CORD C13 TO C20 1.98m Black In Stock £51.84
9N8X APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £287.96
9N8X APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £83.83
9N8X APC Power Cord Locking C19 to C20 3.0m In Stock £69.19
9N8X APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £52.94
9N8X APC Service Pack 3 Year Warranty Extension (for new purchases) In Stock £556.16
9N8X APC Power Cable (pack of 6) 1.22m In Stock £87.14
9N8X APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £131.51
9N8X APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh In Stock £593.25
9N8X APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £101.37
9N8X APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £625.60
9N8X APC Extended Warranty Renewal Technical Support (Renewal) 3 Years In Stock £768.87
9N8X APC Switched Rack PDU AC 208-230 V Ethernet In Stock £746.56
9N8X APC Service Pack 1 Year Warranty Extension In Stock £239.30
9N8X APC Switched PDU 10A 0U C13x16 In Stock £1,164.26
9N8X APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £671.16
9N8X APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,258.82
9N8X APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £161.84
9N8X APC Rack PDU Basic 0U/1U 100-240V/ In Stock £81.63
9N8X APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £470.40
Type: Battery
Brand: APC
Price Range Ex VAT: £1500+
