LCD graphics display has text and mimic diagrams that display modes of operation, system parameters and alarms. Connect the device to a network using a 10 or 100 BASE-T connection. Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Battery failure notification provides early-warning fault analysis on batteries enabling timely preventive maintenance. Rack / tower convertible protects the initial investment in the UPS when migrating from tower to rack-mount environment. Automatic internal bypass supplies utility power to the connected loads in the event of a UPS power overload or fault. Scalable runtime allows additional run time to be quickly added as needed. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging.
Text and mimic diagrams that display modes of operation, system parameters and alarms. -
10/100 BaseT connection
Connect the device to a network using a 10 or 100 BaseT connection -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
- APC Smart-UPS SRT 6000VA RM - UPS - 6000 Watt - 6000 VA
- UPS - rack-mountable
- Rack Size
- 4U
- 60 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 3%
- Power Capacity
- 6000 Watt / 6000 VA
- Input Connectors
- 1 x hardwire 3-wire (1PH + N + G)
- Output connectors
- 6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 1 x hardwire 3-wire (HN + G) , 2 x IEC connector
- Battery
- Lead Acid
- Run Time (Up To)
- 1.5 min at full load
- Networking
- Ethernet 10/100, USB
- Included Accessories
- Rack mounting rails
- Black
- 43.2 cm x 71.9 cm x 17.4 cm
- 3-year warranty
- Designed For
- P/N: ACDC2513, AR3100G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300G, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, AR4038IX429, AR4038IX431, AR4038IX432, NBWL0356A
- Height (Rack Units)
- 4U
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 230 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 3% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 480 Joules
- Efficiency
- 98%
- Technology
- Lead Acid
- Run Time (Up To)
- 1.5 min at full load , 8.1 min at half load
- Recharge Time
- 3 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- 1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Rack Mounting Kit
- Included
- Audible alarm, LCD display
- RoHS, REACH, IP20
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- Sound Emission
- 55 dBA
- 43.2 cm
- 71.9 cm
- 17.4 cm
- 60 kg
- Shipping Width
- 61 cm
- Shipping Depth
- 96 cm
- Shipping Height
- 37 cm
- Shipping Weight
- 67 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, ACF001, ACF002, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.73 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £200.74 |
APC 1U Vertical Cable Organiser | In Stock | £122.11 |
APC 1U Horizontal Cable Organiser | In Stock | £54.76 |
APC Netshelter heavy duty shelf | In Stock | £137.39 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £288.04 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £312.88 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
APC Temperature and Humidity Sensor | In Stock | £147.76 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £281.45 |
APC Rack PDU Basic ZeroU 16A 230V (20)C13 & (4)C19; | In Stock | £312.88 |
APC Cable Managers (Qty 10) | In Stock | £35.36 |
APC 2G Power distribution strip | In Stock | £622.78 |
APC 2U Horizontal Cable Organizer | In Stock | £57.69 |
APC APC POWERCORD C19 TO C20 1.8M | In Stock | £182.09 |
APC Rack PDU 2G METERED ZEROU | In Stock | £682.60 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £962.45 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £924.71 |
APC Power Cord Locking C19 to IEC309-16A 3.0m | In Stock | £84.00 |
APC 17" Rack LCD Console w/ Integrated 8-Port Analog KVM Switch | In Stock | £1,912.00 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £78.78 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £52.95 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,442.54 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £65.60 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £55.91 |
APC Blanking Panel Kit | In Stock | £107.35 |
APC 1U Blanking Panel Kit | In Stock | £33.63 |
APC Service Pack 3 Year Warranty Extension (for new purchases) | In Stock | £521.56 |
APC Smart-UPS SRT 192V 5kVA and 6kVA Battery Pack | In Stock | £1,321.02 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £47.14 |
APC Power Cable (pack of 6) 1.22m | In Stock | £87.88 |
APC Basic Rack PDU Zero U - Power Distribution Panel | In Stock | £351.61 |
APC Dry Contact I/O SmartSlot Card | In Stock | £172.83 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,653.76 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £128.98 |
APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh | In Stock | £568.36 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £613.83 |
APC Extended Warranty Renewal Technical Support (Renewal) 3 Years | In Stock | £742.54 |
APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA | In Stock | £221.27 |
APC Smart-UPS SRT 72V 2.2kVA RM Battery Pack Battery Enclosure | In Stock | £930.67 |
APC Smart-UPS SRT 96V 3kVA RM Battery Pack - Lead Acid | In Stock | £1,228.13 |
APC Smart-UPS SRT 192V 8 and 10kVA RM Battery Pack | In Stock | £1,604.10 |
APC Metered Rack PDU | In Stock | £826.55 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £718.98 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £259.61 |
APC Smart-UPS SRT 72V 2.2kVA Battery Pack | In Stock | £760.83 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,075.99 |
APC Smart-UPS SRT 96V 3kVA Battery Pack | In Stock | £1,182.34 |
APC Service Pack 1 Year Warranty Extension | In Stock | £231.09 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £645.61 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,231.53 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £156.17 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £79.55 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £451.82 |
