Provides pure sine wave output which is recommended by server manufacturers using active power factor corrected (PFC) power supplies. Safety agency tested and approved means that you can deploy Smart-UPS with confidence that they meet or exceed the industry's most rigorous standards.
Network manageable via serial, USB or optional Ethernet. Includes Powerchute Network Shutdown Software for convenient monitoring and control, safe operating system shutdown, and innovative energy management capabilities.
Network grade power conditioning protects from damaging surges and disruptive noise. The double conversion architecture provides tight voltage regulation, frequency regulation, and zero transfer time to battery during power events.
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
- APC Smart-UPS SRT 96V 3kVA Battery Pack - battery enclosure - Lead Acid
- Battery enclosure - external
- 40.6 kg
- Battery
- Lead Acid
- Batteries Qty
- 2
- Black
- 8.5 cm x 59.4 cm x 43.2 cm
- 3-year warranty
- Designed For
- P/N: SRT10KRMXLI, SRT10KXLI, SRT10RMXLIX806, SRT3000XLA, SRT3000XLA-TW, SRT3000XLAUS, SRT3000XLI, SRT3000XLT, SRT3000XLT-5KTF, SRT3000XLTW, SRT3000XLW-IEC, SRT5KXLI, SRT6KRMXLI, SRT6KRMXLI-6W, SRT6KRMXLIM, SRT6KXLI
- Black
- Quantity
- 2
- Technology
- Lead Acid
- Maintenance free, sealed, leak-proof
- RoHS, REACH
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 8.5 cm
- 59.4 cm
- 43.2 cm
- 40.6 kg
- Shipping Width
- 59.9 cm
- Shipping Depth
- 83.1 cm
- Shipping Height
- 23.9 cm
- Shipping Weight
- 44.5 kg
- Designed For
APC 3Yr Extended Warranty SP | In Stock | £323.46 |
APC Smart-UPS SRT UPS 4500 Watt 5000 VA | In Stock | £3,891.93 |
APC Extended Warranty Service Pack Technical Support 1 Year | In Stock | £135.51 |
APC Smart-UPS SRT 19 INCH Rail Kit for SRT 2.2/3kVA | In Stock | £176.65 |
APC Replacement battery cartridge #152 | In Stock | £585.94 |
