APC Smart-UPS SRT 6000VA RM 230V
Quicklinx: 9XF0WS00 Mfr#: SRT6KRMXLI
Type: UPS
Power Rating: 6000Watt
Hurry, only 2 left in stock!
£4,861.35 ex VAT
£5,833.62 inc VAT
LCD graphics display has text and mimic diagrams that display modes of operation, system parameters and alarms. Connect the device to a network using a 10 or 100 BASE-T connection. Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Battery failure notification provides early-warning fault analysis on batteries enabling timely preventive maintenance. Rack / tower convertible protects the initial investment in the UPS when migrating from tower to rack-mount environment. Automatic internal bypass supplies utility power to the connected loads in the event of a UPS power overload or fault. Scalable runtime allows additional run time to be quickly added as needed. Intelligent battery management maximizes battery performance, life, and reliability through intelligent, precision charging.
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • 10/100 BaseT connection
    Connect the device to a network using a 10 or 100 BaseT connection
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
APC Smart-UPS SRT 6000VA RM - UPS - 6000 Watt - 6000 VA
UPS - rack-mountable
Rack Size
4U
60 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 3%
Power Capacity
6000 Watt / 6000 VA
Input Connectors
1 x hardwire 3-wire (1PH + N + G)
Output connectors
6 x power IEC 60320 C13 , 4 x power IEC 60320 C19 , 1 x hardwire 3-wire (HN + G) , 2 x IEC connector
Lead Acid
Run Time (Up To)
1.5 min at full load
Ethernet 10/100, USB
Rack mounting rails
43.2 cm x 71.9 cm x 17.4 cm
3-year warranty
P/N: ACDC2513, AR3100G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300G, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, AR4038IX429, AR4038IX431, AR4038IX432, NBWL0356A
Height (Rack Units)
4U
UPS Technology
On-line
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 230 V ± 3% - 50/60 Hz
Power Capacity
6000 Watt / 6000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Efficiency
98%
Lead Acid
Run Time (Up To)
1.5 min at full load , 8.1 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Rack mounting rails
Rack Mounting Kit
Included
Audible alarm, LCD display
RoHS, REACH, IP20
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
43.2 cm
71.9 cm
17.4 cm
60 kg
Shipping Width
61 cm
Shipping Depth
96 cm
Shipping Height
37 cm
Shipping Weight
67 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, ACF001, ACF002, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
9XF0 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £29.89
9XF0 APC - Power cable - Male-Female - 1.98 m In Stock £50.90
9XF0 APC Basic Rack-Mount PDU - power distribution strip In Stock £202.03
9XF0 APC 1U Vertical Cable Organiser In Stock £122.75
9XF0 APC 1U Horizontal Cable Organiser In Stock £54.86
9XF0 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £52.81
9XF0 APC Netshelter heavy duty shelf In Stock £142.89
9XF0 APC - rack cable guide - 1U In Stock £51.09
9XF0 APC Power cable - 2.4 m In Stock £84.15
9XF0 APC Rack PDU Basic Zero U 16A 208/230V In Stock £299.80
9XF0 APC Rack PDU Basic Zero U 32A 230V In Stock £320.46
9XF0 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
9XF0 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.76
9XF0 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
9XF0 APC Temperature and Humidity Sensor In Stock £133.14
9XF0 APC POWER CORD C13 TO C20 1.98m Black In Stock £52.05
9XF0 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £287.81
9XF0 APC Cable Managers (Qty 10) In Stock £35.34
9XF0 APC Rack PDU 2G METERED ZEROU In Stock £689.69
9XF0 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £984.76
9XF0 APC 19" Rack LCD Console In Stock £1,385.59
9XF0 APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £84.15
9XF0 APC Power Cord Locking C19 to C20 3.0m In Stock £68.64
9XF0 APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.00
9XF0 APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £53.14
9XF0 APC NetShelter Zero U Accessory Mounting Bracket In Stock £66.29
9XF0 APC 1U Blanking Panel Kit In Stock £34.72
9XF0 APC Service Pack 3 Year Warranty Extension (for new purchases) In Stock £527.73
9XF0 APC Smart-UPS SRT 192V 5kVA and 6kVA Battery Pack In Stock £1,346.49
9XF0 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.13
9XF0 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.30
9XF0 APC Power Cable (pack of 6) 1.22m In Stock £87.46
9XF0 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,694.93
9XF0 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.29
9XF0 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £131.85
9XF0 APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh In Stock £585.19
9XF0 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £101.73
9XF0 APC Extended Warranty Renewal Technical Support (Renewal) 3 Years In Stock £771.56
9XF0 APC Smart-UPS SRT 72V 2.2kVA RM Battery Pack Battery Enclosure In Stock £949.02
9XF0 APC Metered Rack PDU In Stock £846.52
9XF0 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £736.14
9XF0 APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £264.70
9XF0 APC Smart-UPS SRT 96V 3kVA Battery Pack In Stock £1,210.54
9XF0 APC Service Pack 1 Year Warranty Extension In Stock £240.13
9XF0 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.44
9XF0 APC Switched PDU 10A 0U C13x16 In Stock £1,164.00
9XF0 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £671.74
9XF0 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,258.20
9XF0 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £162.29
9XF0 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,287.30
9XF0 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £81.93
9XF0 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £470.30
Type: UPS
Brand: APC
Price Range Ex VAT: £1500+
