APC Smart-UPS SRT 5000VA RM 208/230V HW
Quicklinx: D992WS00 Mfr#: SRT5KRMXLW-HW
Type: Power
Hurry, only 1 left in stock!
£4,339.06 ex VAT
£5,206.87 inc VAT
Text and mimic diagrams that display modes of operation, system parameters and alarms. Connect the device to a network using a 10 or 100 BaseT connection.
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Provides early-warning fault analysis on batteries enabling timely preventive maintenance.
  • LCD graphics display
  • 10/100 BaseT connection
  • Green mode
  • Battery failure notification
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
APC Smart-UPS SRT 5000VA RM - UPS - 4500 Watt - 5000 VA
UPS - rack-mountable / external
Rack Size
3U
54.6 kg
Input Voltage
AC 208/230 V
Output Voltage
AC 208/230 V ± 3%
Power Capacity
4500 Watt / 5000 VA
Input Connectors
2 x hardwire 3-wire (2PH + G), hardwire 3-wire (1PH + N + G)
Output connectors
1 x hardwire 3-wire (HN + E) , 1 x hardwire 3-wire (2PH + G)
Lead Acid
Run Time (Up To)
4 min at full load
Ethernet 10/100, USB
Tower stand, rack mounting rails
43.2 cm x 71.94 cm x 13 cm
3-year warranty
P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3340G, AR3340W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, AR4000MVX429, AR4000MVX432, AR4038IX432, NBWL0356A, SMX3000LVUS, SRT1000RMXLA
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 208/230 V
Frequency Provided
50/60 Hz
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 208/230 V ± 3% - 50/60 Hz
Power Capacity
4500 Watt / 5000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 Joules
Efficiency
98%
Lead Acid
Run Time (Up To)
4 min at full load , 11.8 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Rack Mounting Kit
Included
Audible alarm, LCD display
C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
43.2 cm
71.94 cm
13 cm
54.6 kg
Shipping Width
61 cm
Shipping Depth
96 cm
Shipping Height
33 cm
Shipping Weight
67 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR3814, AR4000MV, AR4000MVX429, AR4000MVX432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A, SMX2000LV, SMX3000HVT, SMX3000LVUS, SRT1000RMXLA, SUA3000R2IX38
D992 APC Basic Rack-Mount PDU - power distribution strip In Stock £198.87
D992 APC 1U Vertical Cable Organiser In Stock £120.23
D992 APC 1U Horizontal Cable Organiser In Stock £53.74
D992 APC Netshelter heavy duty shelf In Stock £138.58
D992 APC - rack cable guide - 1U In Stock £49.85
D992 APC Rack PDU Basic Zero U 16A 208/230V In Stock £288.80
D992 APC Rack PDU Basic Zero U 32A 230V In Stock £314.16
D992 APC Temperature and Humidity Sensor In Stock £131.76
D992 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £278.64
D992 APC Cable Managers (Qty 10) In Stock £34.61
D992 APC 2G Power distribution strip In Stock £624.43
D992 APC Rack PDU 2G METERED ZEROU In Stock £676.65
D992 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £964.83
D992 APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £961.34
D992 APC 19" Rack LCD Console In Stock £1,353.74
D992 APC Fixed Shelf - 50lbs/23kg, Black In Stock £79.11
D992 APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,475.88
D992 APC NetShelter Zero U Accessory Mounting Bracket In Stock £64.54
D992 APC 1U Blanking Panel Kit In Stock £33.90
D992 APC Service Pack 3 Year Warranty Extension (for new purchases) In Stock £511.94
D992 APC Smart-UPS SRT 192V 5kVA and 6kVA Battery Pack In Stock £1,274.49
D992 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £54.79
D992 APC Dry Contact I/O SmartSlot Card In Stock £169.64
D992 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,646.47
D992 APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh In Stock £569.93
D992 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £619.04
D992 APC Extended Warranty Renewal Technical Support (Renewal) 3 Years In Stock £729.07
D992 APC Smart-UPS SRT UPS 4500 Watt 5000 VA In Stock £3,806.08
D992 APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA In Stock £218.88
D992 APC Metered Rack PDU In Stock £822.99
D992 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £731.73
D992 APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £265.57
D992 APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,051.44
D992 APC Service Pack 1 Year Warranty Extension In Stock £226.83
D992 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.76
D992 APC Switched PDU 10A 0U C13x16 In Stock £1,137.24
D992 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £668.72
D992 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,225.32
D992 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £156.29
D992 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £80.68
Type: Power
Brand: APC
Price Range Ex VAT: £1500+
