APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA
Quicklinx: BY6HWS00 Mfr#: SRTRK2
Product Type: Rack rail kit
12 In Stock
£220.34 ex VAT
£264.40 inc VAT
High density, double-conversion on-line power protection with scalable runtime. The iBusway for Data Center solution uses bolted snap-fit hangers and plug-in joint connections, which simplify installation and eliminate the need for expensive special tools
Testing - HL
  • Quick installation
    The iBusway for Data Center solution uses bolted snap-fit hangers and plug-in joint connections, which simplify installation and eliminate the need for expensive special tools.
APC - rack rail kit
Rack rail kit
Grey
Rack Size
19"
52.7 cm x 8.9 cm x 4.4 cm
2.73 g
Smart-UPS SRT 10000VA, 5000VA, 6000VA, 8000VA
Rack rail kit
Rack Size
19"
52.7 cm
8.9 cm
4.4 cm
2.73 g
Grey
Mounting Kit
Included
Limited warranty: - 2 years
APC Smart-UPS SRT 10000VA, 5000VA, 6000VA, 8000VA
Brand: APC
