Text and mimic diagrams that display modes of operation, system parameters and alarms. Connect the device to a network using a 10 or 100 BaseT connection.
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Provides early-warning fault analysis on batteries enabling timely preventive maintenance.
LCD graphics display
Text and mimic diagrams that display modes of operation, system parameters and alarms. -
10/100 BaseT connection
Connect the device to a network using a 10 or 100 BaseT connection -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
- APC Smart-UPS SRT 5000VA RM - UPS - 4500 watt - 5000 VA
- UPS - rack-mountable / external
- Rack Size
- 3U
- 54.6 kg
- Input Wiring
- 1-phase
- Input Voltage
- AC 208/240 V
- Output Voltage
- AC 208/230 V ± 3%
- Power Capacity
- 4500 watt / 5000 VA
- Input Connectors
- 2 x hardwire 3-wire (2PH + G), hardwire 3-wire (1PH + N + G)
- Output connectors
- 1 x hardwire 3-wire (HN + E) , 1 x hardwire 3-wire (2PH + G)
- Battery
- Lead Acid
- Run Time (Up To)
- 4 min at full load
- Networking
- Ethernet 10/100, USB
- Included Accessories
- Tower stand, rack mounting rails
- Black
- Pricing Type
- APC Take-Back
- 43.2 cm x 71.94 cm x 13 cm
- 3-year warranty
- Designed For
- P/N: SRT192BP, SRT192BPUS, SRT192RMBP, SRT192RMBPUS
- Height (Rack Units)
- 3U
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 208/240 V
- Frequency Provided
- 50/60 Hz
- Input Wiring
- 1-phase
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 208/230 V ± 3% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 480 joules
- Efficiency
- 98%
- Technology
- Lead Acid
- Run Time (Up To)
- 4 min at full load , 11.8 min at half load
- Recharge Time
- 3 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- 1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Rack Mounting Kit
- Included
- Audible alarm, LCD display
- C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
- Pricing Type
- APC Take-Back
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 3 years ¦ Limited warranty - battery - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- 43.2 cm
- 71.94 cm
- 13 cm
- 54.6 kg
- Shipping Width
- 61 cm
- Shipping Depth
- 96 cm
- Shipping Height
- 33 cm
- Shipping Weight
- 67 kg
- Designed For
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £206.60 |
APC 1U Vertical Cable Organiser | In Stock | £125.43 |
APC 1U Horizontal Cable Organiser | In Stock | £56.26 |
APC Netshelter heavy duty shelf | In Stock | £144.42 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £330.64 |
APC Temperature and Humidity Sensor | In Stock | £132.19 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £297.98 |
APC Cable Managers (Qty 10) | In Stock | £36.89 |
APC 2G Power distribution strip | In Stock | £654.12 |
APC Rack PDU 2G METERED ZEROU | In Stock | £710.98 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £1,015.17 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £973.78 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £82.14 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,498.11 |
APC 1U Blanking Panel Kit | In Stock | £35.27 |
APC Service Pack 3 Year Warranty Extension (for new purchases) | In Stock | £581.69 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.94 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.73 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,743.67 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £70.10 |
APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh | In Stock | £595.61 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £647.80 |
APC Extended Warranty Renewal Technical Support (Renewal) 3 Years | In Stock | £842.66 |
APC Smart-UPS SRT UPS 4500 Watt 5000 VA | In Stock | £4,005.54 |
APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA | In Stock | £231.46 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £744.71 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,113.73 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £63.93 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £682.35 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,285.92 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £166.36 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,325.53 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £468.18 |
