Text and mimic diagrams that display modes of operation, system parameters and alarms. Connect the device to a network using a 10 or 100 BaseT connection.
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Provides early-warning fault analysis on batteries enabling timely preventive maintenance.
LCD graphics display
Text and mimic diagrams that display modes of operation, system parameters and alarms. -
10/100 BaseT connection
Connect the device to a network using a 10 or 100 BaseT connection -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
- APC Smart-UPS SRT 5000VA RM - UPS - 4500 Watt - 5000 VA
- UPS - rack-mountable / external
- Rack Size
- 3U
- 54.6 kg
- Input Voltage
- AC 208/230 V
- Output Voltage
- AC 208/230 V ± 3%
- Power Capacity
- 4500 Watt / 5000 VA
- Input Connectors
- Hardwire
- Output connectors
- 1 x hardwire
- Battery
- Lead Acid
- Run Time (Up To)
- 4 min at full load
- Networking
- Ethernet 10/100, USB
- Included Accessories
- Tower stand, rack mounting rails
- Black
- 43.2 cm x 71.94 cm x 13 cm
- 3-year warranty
- Designed For
- P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3340G, AR3340W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, AR4000MVX429, AR4000MVX432, AR4038IX432, NBWL0356A, SMX3000LVUS, SRT1000RMXLA
- Height (Rack Units)
- 3U
- Black
- UPS Technology
- On-line
- Input Voltage
- AC 208/230 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 45 - 65 Hz
- Input Connectors
- Hardwire
- Power Output Connectors Details
- 1 x hardwire
- Output Voltage
- AC 208/230 V ± 3% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 480 Joules
- Efficiency
- 98%
- Technology
- Lead Acid
- Run Time (Up To)
- 4 min at full load , 11.8 min at half load
- Recharge Time
- 3 hours
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- 1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Rack Mounting Kit
- Included
- Audible alarm, LCD display
- C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
- 43.2 cm
- 71.94 cm
- 13 cm
- 54.6 kg
- Shipping Width
- 61 cm
- Shipping Depth
- 96 cm
- Shipping Height
- 33 cm
- Shipping Weight
- 67 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR3814, AR4000MV, AR4000MVX429, AR4000MVX432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A, SMX2000LV, SMX3000HVT, SMX3000LVUS, SRT1000RMXLA, SUA3000R2IX38
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £200.74 |
APC 1U Vertical Cable Organiser | In Stock | £119.81 |
APC 1U Horizontal Cable Organiser | In Stock | £54.38 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £292.54 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £314.25 |
APC Temperature and Humidity Sensor | In Stock | £149.59 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £281.45 |
APC Rack PDU Basic ZeroU 16A 230V (20)C13 & (4)C19; | In Stock | £317.76 |
APC Cable Managers (Qty 10) | In Stock | £35.29 |
APC 2G Power distribution strip | In Stock | £627.52 |
APC 2U Horizontal Cable Organizer | In Stock | £57.58 |
APC Rack PDU 2G METERED ZEROU | In Stock | £672.12 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £960.61 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £922.94 |
APC 17" Rack LCD Console w/ Integrated 8-Port Analog KVM Switch | In Stock | £1,926.60 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,442.54 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £64.95 |
APC Blanking Panel Kit | In Stock | £107.35 |
APC 1U Blanking Panel Kit | In Stock | £33.57 |
APC Service Pack 3 Year Warranty Extension (for new purchases) | In Stock | £520.56 |
APC Smart-UPS SRT 192V 5kVA and 6kVA Battery Pack | In Stock | £1,331.10 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £47.06 |
APC Basic Rack PDU Zero U - Power Distribution Panel | In Stock | £350.93 |
APC Dry Contact I/O SmartSlot Card | In Stock | £175.12 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,661.01 |
APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh | In Stock | £567.15 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £618.51 |
APC Extended Warranty Renewal Technical Support (Renewal) 3 Years | In Stock | £741.13 |
APC Smart-UPS SRT UPS 4500 Watt 5000 VA | In Stock | £3,892.94 |
APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA | In Stock | £221.73 |
APC Metered Rack PDU | In Stock | £825.58 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £727.91 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,070.54 |
APC Service Pack 1 Year Warranty Extension | In Stock | £230.66 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £644.38 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,217.34 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £156.86 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £80.80 |
