APC Smart-UPS SRT 5000VA RM 208/230V HW
Quicklinx: D992WS00 Mfr#: SRT5KRMXLW-HW
Type: Power
£4,404.20 ex VAT
£5,285.04 inc VAT
Text and mimic diagrams that display modes of operation, system parameters and alarms. Connect the device to a network using a 10 or 100 BaseT connection.
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Provides early-warning fault analysis on batteries enabling timely preventive maintenance.
  • LCD graphics display
  • 10/100 BaseT connection
  • Green mode
  • Battery failure notification
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
APC Smart-UPS SRT 5000VA RM - UPS - 4500 watt - 5000 VA
UPS - rack-mountable / external
Rack Size
3U
54.6 kg
Input Wiring
1-phase
Input Voltage
AC 208/240 V
Output Voltage
AC 208/230 V ± 3%
Power Capacity
4500 watt / 5000 VA
Input Connectors
2 x hardwire 3-wire (2PH + G), hardwire 3-wire (1PH + N + G)
Output connectors
1 x hardwire 3-wire (HN + E) , 1 x hardwire 3-wire (2PH + G)
Lead Acid
Run Time (Up To)
4 min at full load
Ethernet 10/100, USB
Tower stand, rack mounting rails
Pricing Type
APC Take-Back
Packaging Recycled Content
Made of recycled cardboard
43.2 cm x 71.94 cm x 13 cm
3-year warranty
P/N: SRT192BP, SRT192BPUS, SRT192RMBP, SRT192RMBPUS
Height (Rack Units)
3U
UPS Technology
On-line
Input Voltage
AC 208/240 V
Frequency Provided
50/60 Hz
Input Wiring
1-phase
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
AC 208/230 V ± 3% - 50/60 Hz
Power Capacity
4500 watt / 5000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
480 joules
Efficiency
98%
Lead Acid
Run Time (Up To)
4 min at full load , 11.8 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (Ethernet) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , 1 x EPO (emergency power off) , 1 x serial - RJ-45
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Rack Mounting Kit
Included
Audible alarm, LCD display
C-Tick, VDE, IEC 60950, EN 50091-2, RoHS, EN 50091-1, REACH, EN 62040-2, IP20, EAC
Pricing Type
APC Take-Back
Software Included
APC PowerChute Business Edition
Sustainability Information
Limited warranty - 3 years , Limited warranty - battery - 2 years
0 - 95% (non-condensing)
43.2 cm
71.94 cm
13 cm
54.6 kg
Shipping Width
61 cm
Shipping Depth
96 cm
Shipping Height
33 cm
Shipping Weight
67 kg
D992 APC Basic Rack-Mount PDU - power distribution strip In Stock £204.64
D992 APC 1U Vertical Cable Organiser In Stock £124.80
D992 APC 1U Horizontal Cable Organiser In Stock £55.47
D992 APC Netshelter heavy duty shelf In Stock £141.95
D992 APC Rack PDU Basic Zero U 16A 208/230V In Stock £302.47
D992 APC Rack PDU Basic Zero U 32A 230V In Stock £326.06
D992 APC Temperature and Humidity Sensor In Stock £130.29
D992 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £289.09
D992 APC Cable Managers (Qty 10) In Stock £36.38
D992 APC 2G Power distribution strip In Stock £649.15
D992 APC Rack PDU 2G METERED ZEROU In Stock £687.91
D992 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £511.74
D992 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,000.76
D992 APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £959.96
D992 APC 19" Rack LCD Console In Stock £1,370.27
D992 APC Vertical Cable Organizer, NetShelter SX, 42U In Stock £94.52
D992 APC Fixed Shelf - 50lbs/23kg, Black In Stock £80.88
D992 APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,510.33
D992 APC NetShelter Zero U Accessory Mounting Bracket In Stock £99.01
D992 APC 1U Blanking Panel Kit In Stock £34.80
D992 APC Service Pack 3 Year Warranty Extension (for new purchases) In Stock £575.47
D992 APC Smart-UPS SRT 192V 5kVA and 6kVA Battery Pack In Stock £1,345.06
D992 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £55.94
D992 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.98
D992 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,642.73
D992 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.11
D992 APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh In Stock £575.20
D992 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £638.53
D992 APC Extended Warranty Renewal Technical Support (Renewal) 3 Years In Stock £818.29
D992 APC Smart-UPS SRT 19 Rail Kit for Smart-UPS SRT 5/6/8/10kVA In Stock £227.30
D992 APC Metered Rack PDU In Stock £856.35
D992 APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £265.59
D992 APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,097.93
D992 APC Service Pack 1 Year Warranty Extension In Stock £265.19
D992 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.16
D992 APC Rack PDU 2G Metered-by-Outlet ZeroU 32A 230V (21) C13+(3)$ In Stock £1,207.93
D992 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £677.83
D992 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,261.34
D992 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £163.11
D992 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,306.71
D992 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £84.13
D992 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £472.34
Type: Power
Brand: APC
Price Range Ex VAT: £1500+
