APC Smart-UPS SRT 2200VA RM 230V
Quicklinx: C10MWS00 Mfr#: SRT2200RMXLI
Power Rating: 1980Watt
£1,828.99 ex VAT
£2,194.78 inc VAT
Provides pure sine wave output which is recommended by server manufacturers using active power factor corrected (PFC) power supplies. Safety agency tested and approved means that you can deploy Smart-UPS with confidence that they meet or exceed the industry's most rigorous standards.
Network grade power conditioning protects from damaging surges and disruptive noise. The double conversion architecture provides tight voltage regulation, frequency regulation, and zero transfer time to battery during power events.
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms.
  • ECO Mode
    Operating mode that by-passes unused electrical components in good power conditions to achieve high operating efficiency without sacrificing protection.
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
APC Smart-UPS SRT 2200VA RM - UPS - 1980 Watt - 2200 VA - Lead Acid
UPS - rack-mountable / external
Rack Size
2U
25 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V
Power Capacity
1980 Watt / 2200 VA
Input Connectors
3 x power IEC 60320 C20, power BS 1363A, Europlug (power CEE 7/16)
Output connectors
8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
Lead Acid Lead Acid
Batteries Qty
1
Run Time (Up To)
3.9 min at full load
RS-232, USB
43.2 cm x 58.4 cm x 8.5 cm
Environmental Standards
ENERGY STAR
3-year warranty
P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155SP, AR3155W, AR3300W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Height (Rack Units)
2U
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 275 V
Input Voltage Range (Adjustable)
AC 100 - 275 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V 50/60 Hz
Power Capacity
1980 Watt / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
340 Joules
Efficiency
96%, 92% at 100% Load
Quantity
1
Lead Acid Lead Acid
Run Time (Up To)
3.9 min at full load , 11.6 min at half load
Recharge Time
3 hours
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x EPO (emergency power off) , 1 x management (USB) - 4 pin USB Type A
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Power cable 2.44 m , Serial cable - external , USB cable - external
Rack Mounting Kit
Included
Audible alarm, emergency power off, LCD display, internal bypass, Eco-Mode
VDE, IEC 62040-2, RoHS, EN 62040-2, IP20, EAC, RCM, IEC 62040-1, EN 62040-1
Software Included
APC PowerChute Business Edition
Sustainability Information
ENERGY STAR
Limited warranty - replacement - 3 years , Limited warranty - batteries - 2 years
0 - 95% (non-condensing)
Sound Emission
55 dBA
43.2 cm
58.4 cm
8.5 cm
25 kg
Shipping Width
59.9 cm
Shipping Depth
81 cm
Shipping Height
24.6 cm
Shipping Weight
34.02 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR3814, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
C10M APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.95
C10M APC Basic Rack-Mount PDU - power distribution strip In Stock £209.65
C10M APC Pwr Cord, 16A, 200-240V, C19 to UK Plug In Stock £60.80
C10M APC Power cable - 2.4 m In Stock £87.33
C10M APC Rack PDU, Basic, Zero U, 10A,2 In Stock £280.19
C10M APC Rack PDU Basic Zero U 16A 208/230V In Stock £311.67
C10M APC 3Yr Extended Warranty SP In Stock £335.04
C10M APC Temperature and Humidity Sensor In Stock £133.03
C10M APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £979.84
C10M APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £87.33
C10M APC Power Cord Kit (6 ea) Locking C19 to C20 1.2m In Stock £154.75
C10M APC Power Cable (pack of 6) 1.22m In Stock £90.64
C10M APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £105.21
C10M APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £651.82
C10M APC Smart-UPS SRT 72V 2.2kVA RM Battery Pack Battery Enclosure In Stock £976.85
C10M APC Switched Rack PDU AC 208-230 V Ethernet In Stock £762.02
C10M APC Smart-UPS SRT 19 INCH Rail Kit for SRT 2.2/3kVA In Stock £181.47
C10M APC Replacement Battery Cartridge #141 In Stock £374.58
C10M APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £63.46
C10M APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £677.15
C10M APC Rack PDU Basic 0U/1U 100-240V/ In Stock £83.83
C10M APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £480.48
Brand: APC
Price Range Ex VAT: £1500+
