Smart-UPS SRT provides high density, true double-conversion power protection for servers, voice / data networks, medical labs, and light industrial applications. When business-critical systems require runtime in hours, not minutes, Smart-UPS SRT can be configured with matching battery packs to comply with aggressive runtime demands. It provides customers with a reliable source of uninterruptible power even in demanding power environments, including very wide input voltage window, extremely tight output voltage regulation, frequency regulation, internal bypass, and input power factor correction.
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
- APC Smart-UPS SRT 72V 2.2kVA RM Battery Pack - battery enclosure - Lead Acid
- Battery enclosure - rack-mountable
- Rack Size
- 2U
- 33.9 kg
- Battery
- Lead Acid
- Batteries Qty
- 2
- Black
- 43.2 cm x 59.4 cm x 8.5 cm
- 3-year warranty
- Designed For
- P/N: AR3003, AR3003SP, AR3006, AR3006SP, AR3103, AR3103SP, AR3106, AR3106SP, AR3357X674, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, SRT10KRMXLI, SRT10KXLI, SRT10RMXLIX806, SRT2200RMXLA, SRT2200RMXLA-NC, SRT2200RMXLAUS, SRT2200RMXLI, SRT2200RMXLI-NC, SRT5KXLI, SRT6KRMXLI, SRT6KRMXLI-6W, SRT6KRMXLIM
- Height (Rack Units)
- 2U
- Black
- Quantity
- 2
- Technology
- Lead Acid
- Maintenance free, sealed, leak-proof
- RoHS, REACH
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 43.2 cm
- 59.4 cm
- 8.5 cm
- 33.9 kg
- Shipping Width
- 59.9 cm
- Shipping Depth
- 83.1 cm
- Shipping Height
- 23.9 cm
- Shipping Weight
- 40.82 kg
- Designed For
APC Smart-UPS SRT UPS 4500 Watt 5000 VA | In Stock | £3,891.93 |
APC Smart-UPS SRT 19 INCH Rail Kit for SRT 2.2/3kVA | In Stock | £176.65 |
APC 1 Year Extended Warranty 2015-4037 | In Stock | £62.04 |
APC Service Pack 3 Year Warranty Extension | In Stock | £115.77 |
APC Replacement Battery Cartridge #141 | In Stock | £363.87 |
