APC Smart UPS SMT3000IC
Quicklinx: FCKBWS00 Mfr#: SMT3000IC
Power Rating: 2700Watt
£1,656.26 ex VAT
£1,987.51 inc VAT
Intelligent and efficient network power protection from entry level to scaleable runtime. Ideal UPS for servers, point-of-sale, routers, switches, hubs and other network devices.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Intelligent Card Slot
    Mini slot supports various optional management cards which provide basic or essential monitoring, management and control features for the UPS.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Sequenced network shutdown and reboot
    Customize network shutdown and reboot sequence of connected servers and UPSs.
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
  • StruxureWare Data Center Expert compatible
    Enables centralized management via StruxureWare Data Center Expert.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS SMT3000IC - UPS - 2700 Watt - 3000 VA - with APC SmartConnect
UPS - external
52.5 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
2700 Watt / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 2 x IEC jumper , 1 x power IEC 60320 C19
Lead Acid
Batteries Qty
1
Run Time (Up To)
5.1 min at full load
RS-232, USB
19.7 cm x 54.4 cm x 43.5 cm
3-year warranty
Bundled with
APC SmartConnect
UPS - external
Bundled with
APC SmartConnect
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
50/60 Hz ± 3Hz
Frequency Required
50/60 Hz ± 3Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 50/60 Hz
Power Capacity
2700 Watt / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
365 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
5.1 min at full load , 17.2 min at half load
Recharge Time
3 hours
Transfer Time
6 ms
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (RS-232) , 1 x USB , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external , USB cable - external
Audible alarm, emergency power off, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic self-test, predicitive failure notification, hot-swappable batteries, energy metre
CSA, UL 1778, VDE, IEC 62040-2, RoHS, EN 62040-2, EAC, RCM, IEC 62040-1, EN 62040-1
Software Included
APC PowerChute Business Edition
Limited warranty - replace or repair - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
45 dBA
19.7 cm
54.4 cm
43.5 cm
52.5 kg
Shipping Width
38.1 cm
Shipping Depth
76.2 cm
Shipping Height
69.9 cm
Shipping Weight
63.7 kg
FCKB APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £28.30
FCKB APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £49.51
FCKB APC - Power cable - Male-Female - 1.98 m In Stock £49.24
FCKB APC Basic Rack-Mount PDU - power distribution strip In Stock £203.09
FCKB APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £52.60
FCKB APC Power cable - 2.4 m In Stock £83.54
FCKB APC Rack PDU Basic Zero U 16A 208/230V In Stock £294.54
FCKB APC Replacement Battery Cartridge RBC55 In Stock £424.55
FCKB APC 3Yr Extended Warranty SP In Stock £333.59
FCKB APC Temperature and Humidity Sensor In Stock £134.30
FCKB APC POWER CORD C13 TO C20 1.98m Black In Stock £51.68
FCKB APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £286.43
FCKB APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £84.10
FCKB APC Power Cord Locking C19 to C20 3.0m In Stock £69.38
FCKB APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £52.24
FCKB APC Power Cable (pack of 6) 1.22m In Stock £85.96
FCKB APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £130.73
FCKB APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £633.29
FCKB APC Extended Warranty Service Pack Technical Support 1 Year In Stock £124.04
FCKB APC Switched Rack PDU AC 208-230 V Ethernet In Stock £740.02
FCKB APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £61.06
FCKB APC Switched PDU 10A 0U C13x16 In Stock £1,136.42
FCKB APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,252.97
FCKB APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £161.08
FCKB APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.74
FCKB APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £468.44
Brand: APC
Price Range Ex VAT: £1500+
