APC Switched PDU 10A 0U C13x16
Quicklinx: D8VWWS00 Mfr#: AP7950B
16 In Stock
£1,139.17 ex VAT
£1,367.00 inc VAT
APC's Switched Rack Power Distribution Units (PDUs) are premium solutions to many of the power management problems seen in today's IT environments. Some of the problems are unauthorized use of power outlets, locked-up equipment, in-rush current, overloaded circuits, and the need of remote access to power outlets in the rack. The Switched Rack PDUs address these problems through individual outlet control, power on and off delays, current monitoring, alarm thresholds, and network management. Individual outlet control allows users to turn outlets on, turn outlets off, or recycle power to equipment, which can reboot locked-up equipment and avoid unauthorized use of outlets. Power delays allow users to determine the order in which equipment is powered up or down. Utilizing the power delay feature will avoid in-rush current, which can cause overloads. Monitoring the current draw at the rack level is key to avoiding downtime due to overloaded circuits. The Switched Rack PDUs provide an aggregate current draw, which can be viewed remotely or locally, via digital display. In addition, alarms will be generated based on user-defined thresholds to alert users of potential circuit overloads. Users can access, configure, and control the Switched Rack PDUs through Web, SNMP, or Telnet Interfaces.
  • Remote Management Capabilities
    Full-featured network management interfaces that provide standards-based management via Web, SNMP, and Telnet. Allows users to access, configure, and manage units from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements
  • Flash Upgradeable
    Quickly and easily upgrade firmware via network download for future product enhancements. Eliminates the need to replace products already installed in the field when new features are released. (Note: Networked units only)
APC Switched Rack PDU Zero U - power distribution strip
Power distribution strip - rack-mountable
Cord Length
3.05 m
4.32 g
Input Voltage
AC 200/208/230 V
Output Voltage
AC 230 V
Input Connectors
1 x power IEC 60320 C14
Output connectors
16 x power IEC 60320 C13
Ethernet 10/100
Remote Management Protocol
SNMP, Telnet, HTTP
5.6 cm x 4.4 cm x 124.5 cm
P/N: SCL400RMJ1U, SCL500RM1UC, SCL500RM1UNC, SCL500RMI1UC, SCL500RMI1UNC, SMT1500R2I-AR, SMT2200I-AR, SMT2200R2I-AR, SMT3000I-AR, SMT3000R2I-AR, SMTL1000RM2UC, SMTL750RM2UC, SMTL750RMI2UC, SMX2KR2UNCX145, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500RMXLI, SRT1500XLI, SRT2200XLI-KR, SRT5KRMXLW-TW
Cord Length
3.05 m
Input Voltage
AC 200/208/230 V
Input Voltage Range
AC 200 - 240 V
Input Connectors
Output Voltage
AC 230 V
Max Electric Current
10 A
Remote Management Interface
Ethernet 10/100
SNMP, Telnet, HTTP
1 x management (Ethernet) - RJ-45 ¦ 1 x serial - RJ-11
Power cable 3.05 m
Rack Mounting Kit
Included
LED display, current meter
GOST, EN 61000-3-2, VDE, EN 61000-3-3, EN55024, IRAM, RoHS, REACH, EN 55022 Class A
Limited warranty - parts and labour - 2 years
-5 °C
45 °C
0 - 95%
5.6 cm
4.4 cm
124.5 cm
4.32 g
Shipping Width
15.2 cm
Shipping Depth
12.7 cm
Shipping Height
213.4 cm
Shipping Weight
5.23 kg
P/N: AR3355W, AR3357X674, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4038IX432, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBPD0160A, NBWL0355A, NBWL0356A, SCL400RMJ1U, SCL500RM1UC, SCL500RM1UNC, SCL500RMI1UC, SCL500RMI1UNC, SMC1000-2UC, SMC1000-2UTW, SMC1000-BR, SMC1000I-2UC, SMC1000I-BR, SMC1000IC, SMC15002U-BR, SMC1500-2UC, SMC1500-2UTW, SMC1500-BR, SMC1500I2U-BR, SMC1500I-2UC, SMC1500I-BR, SMC1500IC, SMC2000I2U-BR, SMT1000I-AR, SMT1000IC, SMT1000R2I-AR, SMT1000RM2UC, SMT1000RMI2UC, SMT1500I-AR, SMT1500IC, SMT1500R2I-AR, SMT1500RM2UC, SMT1500RM2UNC, SMT1500RMI2UC, SMT1500RMI2UNC, SMT2200I2U-BR, SMT2200I-AR, SMT2200IC, SMT2200R2I-AR, SMT2200RM2UC, SMT2200RM2UNC, SMT2200RMI2UC, SMT2200RMI2UNC, SMT30002U-BR, SMT3000I2U-BR, SMT3000I-AR, SMT3000IC, SMT3000R2I-AR, SMT3000RM2UC, SMT3000RM2UNC, SMT3000RMI2UC, SMT3000RMI2UNC, SMT750RM2UC, SMT750RM2UNC, SMT750RMI2UC, SMT750RMI2UNC, SMTL1000RM2UC, SMTL750RM2UC, SMTL750RMI2UC, SMX1000US, SMX1500RMNCUS, SMX1500RMUS, SMX2000LVNCUS, SMX2000LVUS, SMX2200HVNC, SMX2200R2HVNC, SMX2200RMLVUS, SMX2KR2UNCX145, SMX2KRMLVNCUS, SMX3000HV-BR, SMX3000HVTUS, SMX3000LV2U-BR, SMX3000LVNCUS, SMX3000LVUS, SMX3000RMLVUS, SMX3KRMLVNCUS, SMX750INC, SMX750NC, SMX750US, SRC2000XLI-CC, SRC3KUXI, SRT1000RMXLA, SRT1000RMXLA-NC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT10KRMXLT-10KTF, SRT10KRMXLT30, SRT10KRMXLT-5KTF2, SRT10RMXLIX806, SRT1500RMXLA, SRT1500RMXLA-NC, SRT1500RMXLI, SRT1500XLI, SRT2200RMXLA, SRT2200RMXLA-NC, SRT2200RMXLAUS, SRT2200RMXLI, SRT2200RMXLI-NC, SRT2200XLI, SRT2200XLI-KR, SRT3000RMXLA, SRT3000RMXLA-NC, SRT3000RMXLI, SRT3000RMXLI-NC, SRT3000RMXLT, SRT3000RMXLT-5KTF, SRT3000RMXLT-NC, SRT3000RMXLW-IEC, SRT3000XLI, SRT3000XLW-IEC, SRT5KRMXLIM, SRT5KRMXLT-5KTF, SRT5KRMXLTUS, SRT5KRMXLW-TW, SRT6KRMXLIM, SRT6KRMXLT-5KTF, SRT8KRMXLT30, SRT8KRMXLT-5KTF, SUA1000ICH-45, SUA1000RM2UTW, SUA1500I-IN, SUA2200ICH-45, SUA2200RM2UTW, SUA3000I-IN, SURT1000RMXLI-NC, SURT1000XLI-NC, SYAF16KRMICH
D8VW APC 1U Vertical Cable Organiser In Stock £120.69
D8VW APC 1U Horizontal Cable Organiser In Stock £53.96
D8VW APC Netshelter heavy duty shelf In Stock £138.81
D8VW APC - rack cable guide - 1U In Stock £50.03
D8VW APC Rackmount Rail Kit In Stock £88.80
D8VW APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £206.33
D8VW APC Equipment Support Rails for 600mm Wide Enclosure In Stock £71.78
D8VW APC Cable Managers (Qty 10) In Stock £34.75
D8VW APC 19" Rack LCD Console In Stock £1,356.02
D8VW APC Fixed Shelf - 50lbs/23kg, Black In Stock £79.42
D8VW APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,475.88
D8VW APC NetShelter Zero U Accessory Mounting Bracket In Stock £64.55
D8VW APC 1U Blanking Panel Kit In Stock £34.04
D8VW APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £54.88
D8VW APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.24
D8VW APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,649.26
D8VW APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.73
D8VW APC Metered Rack PDU In Stock £824.38
D8VW APC Switched Rack PDU AC 208-230 V Ethernet In Stock £726.63
D8VW APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £265.57
D8VW APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,052.88
D8VW APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.86
D8VW APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,226.61
D8VW APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £156.90
D8VW APC Rack PDU Basic 0U/1U 100-240V/ In Stock £80.83
Brand: APC
Price Range Ex VAT: £1000 - £1500
