APC Smart-UPS RT 20kVA RM 230V
Quicklinx: 5LL8WS00 Mfr#: SURT20KRMXLI
Type: UPS
Power Rating: 16kW
Hurry, only 2 left in stock!
£12,354.37 ex VAT
£14,825.24 inc VAT
Increases availability by allowing the UPS to be connected to two separate power sources. Reduces preventative maintenance service needs by monitoring the health and status of the external batteries and their expected runtime.
  • Dual mains input
  • LCD display
    Manage the UPS locally through a text-based display that allows quick diagnosis via stored alarm conditions and events.
  • Manageable external batteries
  • Rack/Tower convertible
    Protects the initial investment in the UPS when migrating from tower to rack-mount environment.
  • Removable input/output wiring tray
    Allows quick and easy installation and maintenance of the UPS.
  • Single or three-phase input wireable
    Provides flexibility for the UPS to be installed using either single or three-phase input wiring.
APC Smart-UPS RT - UPS - 16 kW - 20000 VA
UPS - rack-mountable
Rack Size
12U
248 kg
Input Wiring
3-phase / 1-phase
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
16 kW / 20000 VA
Input Connectors
1 x hardwire 5-wire (3PH + N + G), hardwire 3-wire (1PH + N + G)
Output connectors
1 x hardwire 3-wire (2PH + G) , 1 x hardwire 5-wire (3PH + N + G) , 8 x power IEC 60320 C19
Lead Acid
Battery Form Factor
Plug-in module
Batteries Qty
4
Run Time (Up To)
4.9 min at full load
Ethernet 10/100, RS-232
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS
43.2 cm x 77.3 cm x 53.3 cm
P/N: AR2200, AR2280, AR2487G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3140G, AR3140W, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300G, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3340G, AR3340W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, NBWL0356A
Battery Enclosure Type
Plug-in module
Height (Rack Units)
12U
UPS Technology
On-line
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 280 V
Frequency Provided
50/60 Hz
Input Wiring
3-phase / 1-phase
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V ± 5% - 50/60 Hz
Power Capacity
16 kW / 20000 VA
Output Waveform
Sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Quantity
4
Lead Acid
Voltage Provided
192 V
Run Time (Up To)
Recharge Time
2.5 hours
Remote Management Interface
1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (Ethernet) - RJ-45 , 1 x EPO (emergency power off)
Expansion Slots
SmartSlot
Serial cable - external
Rack Mounting Kit
Included
Audible alarm, emergency power off, LCD display, built-in static bypass, internal bypass
UL 1449, VDE, IEC 62040-1-1
Software Included
APC PowerChute Business Edition
0 - 95%
Sound Emission
59 dBA
43.2 cm
77.3 cm
53.3 cm
248 kg
Shipping Width
61 cm
Shipping Depth
100 cm
Shipping Height
99 cm
Shipping Weight
314 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
5LL8 APC - Power cable - Male-Female - 1.98 m In Stock £51.34
5LL8 APC Basic Rack-Mount PDU - power distribution strip In Stock £203.85
5LL8 APC 1U Vertical Cable Organiser In Stock £124.59
5LL8 APC 1U Horizontal Cable Organiser In Stock £55.36
5LL8 APC Netshelter heavy duty shelf In Stock £143.47
5LL8 APC Power cable - 2.4 m In Stock £86.26
5LL8 APC Rack PDU Basic Zero U 16A 208/230V In Stock £298.78
5LL8 APC Rack PDU Basic Zero U 32A 230V In Stock £323.36
5LL8 APC NETSHELTER SX 24U In Stock £1,157.46
5LL8 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
5LL8 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.76
5LL8 APC Temperature and Humidity Sensor In Stock £134.43
5LL8 APC POWER CORD C13 TO C20 1.98m Black In Stock £52.50
5LL8 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £288.97
5LL8 APC Rack PDU Basic ZeroU 16A 230V (20)C13 & (4)C19; In Stock £323.36
5LL8 APC Cable Managers (Qty 10) In Stock £35.65
5LL8 APC 2G Power distribution strip In Stock £648.88
5LL8 APC Rack PDU 2G METERED ZEROU In Stock £700.20
5LL8 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £993.47
5LL8 APC 19" Rack LCD Console In Stock £1,390.80
5LL8 APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £84.91
5LL8 APC Power Cord Locking C19 to C20 3.0m In Stock £69.94
5LL8 APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.68
5LL8 APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £53.64
5LL8 APC NetShelter Zero U Accessory Mounting Bracket In Stock £67.39
5LL8 APC 1U Blanking Panel Kit In Stock £35.01
5LL8 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £57.23
5LL8 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.70
5LL8 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,694.93
5LL8 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £71.36
5LL8 APC Replacement Battery Cartridge #140 - UPS battery - Lead Acid - 960 Wh In Stock £600.27
5LL8 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £633.65
5LL8 APC Metered Rack PDU In Stock £850.13
5LL8 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £749.97
5LL8 APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £265.77
5LL8 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £674.28
5LL8 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,263.27
5LL8 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £162.41
5LL8 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,298.69
5LL8 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.68
5LL8 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £472.06
Resources
The following resources are available for the APC Smart-UPS RT 20kVA RM 230V
Type: UPS
Power Rating: 16kW
Brand: APC
Price Range Ex VAT: £1500+
