APC Smart-UPS 2200VA LCD RM 2U 230V
Quicklinx: 7M78WS00 Mfr#: SMT2200RMI2U
Type: UPS
Power Rating: 1.98kW
£1,423.04 ex VAT
£1,707.64 inc VAT
APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and networks.
Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption.
Available in a variety of form factors (tower, rack mount, rack/tower convertible) there is a model for every application and budget. Smart-UPS models have long been considered the benchmark for all network and server UPS's. Smart-UPS feature a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery. Additional manageability options are available through the Smart-Slot interface, which is an internal slot for the installation of optional accessory cards.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Intelligent Card Slot
    Customize UPS capabilities with management cards.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Sequenced network shutdown and reboot
    Customize network shutdown and reboot sequence of connected servers and UPSs.
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • StruxureWare Data Center Expert compatible
    Enables centralized management via StruxureWare Data Center Expert.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS 2200 LCD - UPS - 1.98 kW - 2200 VA
UPS - rack-mountable
Rack Size
2U
42.3 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V
Power Capacity
1.98 kW / 2200 VA
Input Connectors
3 x power IEC 60320 C20, power CEE 7/7, power BS 1363A
Output connectors
8 x power IEC 60320 C13 , 3 x IEC jumper , 1 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
5.4 min at full load
RS-232, USB
48 cm x 68.3 cm x 8.6 cm
3-year warranty
P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155SP, AR3155W, AR3300W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 299 V
Frequency Provided
47 - 53 / 57 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V 47 - 53 / 57 - 63 Hz
Power Capacity
1.98 kW / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
375 Joules
Lead Acid
Run Time (Up To)
5.4 min at full load , 16.1 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x USB , 1 x serial
Expansion Slots
1 SmartSlot
Serial cable , USB cable , Power cable - integrated - 2 m
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR)
C-Tick, GOST, EN 60950, GS, VDE, IEC 62040-1-1, RoHS Exemption 7b, IEC 62040-2, IRAM, WEEE
Software Included
Drivers & Utilities
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
55 dBA
48 cm
68.3 cm
8.6 cm
42.3 kg
Shipping Width
60 cm
Shipping Depth
98 cm
Shipping Height
25.4 cm
Shipping Weight
49.7 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
7M78 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £28.90
7M78 APC - Power cable - Male-Female - 1.98 m In Stock £47.79
7M78 APC Basic Rack-Mount PDU - power distribution strip In Stock £197.72
7M78 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £50.88
7M78 APC Pwr Cord, 16A, 200-240V, C19 to UK Plug In Stock £56.28
7M78 APC Replacement Battery Cartridge #43 - UPS battery - Lead Acid In Stock £416.09
7M78 APC Power cable - 2.4 m In Stock £82.25
7M78 APC Rack PDU Basic Zero U 16A 208/230V In Stock £286.90
7M78 APC 2-Post Mounting Kit for Smart-UPS In Stock £169.50
7M78 APC 3Yr Extended Warranty SP In Stock £288.00
7M78 APC Temperature and Humidity Sensor In Stock £130.81
7M78 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £271.25
7M78 APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £953.12
7M78 APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £85.03
7M78 APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £51.95
7M78 APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £56.28
7M78 APC Power Cable (pack of 6) 1.22m In Stock £84.43
7M78 APC Dry Contact I/O SmartSlot Card In Stock £165.13
7M78 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £126.10
7M78 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £100.67
7M78 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £614.64
7M78 APC Extended Warranty Service Pack Technical Support 1 Year In Stock £120.61
7M78 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £731.73
7M78 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.34
7M78 APC Switched PDU 10A 0U C13x16 In Stock £1,129.15
7M78 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £668.72
7M78 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,217.48
7M78 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £155.82
7M78 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £80.21
Type: UPS
Brand: APC
Price Range Ex VAT: £1000 - £1500
