Housing equipment with side-to-side airflow creates many challenges for IT and facility managers, particularly in regards to cooling. Because most enclosures are designed for a front to back airflow pattern, it is difficult to maintain ideal operating temperatures on side-to-side airflow equipment. The Rack Side Air Distribution Unit allows for greater security and organization by allowing racks to be placed adjacent to one another without impeding airflow.
The Rack Side Air Distribution Unit is a 2U rack mountable air distribution product for networking equipment or servers with side-to-side airflow. It pulls in conditioned air from the front of the rack and distributes it to the side air intake of the networking equipment. This extends equipment life by providing proper inlet temperatures.
This product is recommended for one or more networking products that are stacked consecutively in a rack. Rack Side Air Distribution Units may be placed above and/or below the networking equipment. Airflow pattern is user configurable via an interchangeable air turning vane.
Resettable circuit breakers
Enables a quick recovery from overload events -
Dual A-B Power Inputs
Draws power from the UPS for power protection with dual feeds for redundancy -
Dual fans
Provides fault tolerance in the event of a fan failure -
Fan control switches
Users can turn one or both fans on and off depending on the heat load -
Mounting rails
Adjustable depth allows the unit to fit APC NetShelter enclosures or other 19" EIA-310-D enclosures -
Air turning vane
Directs air up or down the side of the rack, supplying cool air to the inlet of side-to-side airflow equipment
- APC Rack Side Air Distribution 208/230V 50/60HZ - fan unit - 2U
- Product Type
- Fan unit
- Black
- Height (Rack Units)
- 2U
- 66 cm x 79 cm x 8.6 cm
- 15 kg
- 2-year warranty
- Designed For
- P/N: AP8702S-WWX340, AP8704S-WWX340, AP8706S-WWX340, AR3103, AR3103SP, AR3106SP, AR3357X674, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBPD0160A, NBWL0355A, NBWL0356A, SMC1500I-2UC, SMX2000LVNCUS, SMX2000LVUS, SMX3000HV-BR, SMX3000HVTUS, SMX3000LVUS, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500RMXLA-NC
- Product Type
- Fan unit
- 2U
- 66 cm
- 79 cm
- 8.6 cm
- 15 kg
- Black
- UL
- Limited warranty: - 2 years
- Designed For
- P/N: ACCS1006, ACCS1007, ACDC2513, AP5602, AP5606, AP5607, AP5616, AP7857, AP7950B, AP7957, AP8702R-NA, AP8702R-WW, AP8702S-NA, AP8702S-NAX340, AP8702S-NAX590, AP8702S-WW, AP8702S-WWX340, AP8702S-WWX590, AP8704R-NA, AP8704R-WW, AP8704S-NA, AP8704S-NAX340, AP8704S-NAX590, AP8704S-WW, AP8704S-WWX340, AP8704S-WWX590, AP8706R-NA, AP8706R-WW, AP8706S-NA, AP8706S-NAX340, AP8706S-NAX590, AP8706S-WW, AP8706S-WWX340, AP8706S-WWX591, AP8717, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3100G, AR3100SP, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3103, AR3103SP, AR3105, AR3105SP, AR3105W, AR3106SP, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3140, AR3140G, AR3140W, AR3150SP, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, AR3810, AR3812, AR3814, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, DLA1500RM2U, NBPD0160A, NBPD0171, NBWL0355A, NBWL0356A, SMC1000-BR, SMC15002U-BR, SMC1500I-2U, SMC1500I2U-BR, SMC1500I-2UC, SMC1500I-BR, SMT3000I2U-BR, SMX2000LV, SMX2000LVNC, SMX2000LVNCUS, SMX2000LVUS, SMX2200R2HVNC, SMX3000HV-BR, SMX3000HVT, SMX3000HVTUS, SMX3000LV, SMX3000LV2U-BR, SMX3000LVUS, SRT1000RMXLA, SRT1000RMXLA-NC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500RMXLA, SRT1500RMXLA-NC, SU3000RMJ3U3W, SU3000RMJ3UOS3, SUA2200R3XLNETPKG, SUA3000R3XLNETPKG, SUA3000RMXL3U-BR, SUA750R2X122, SURT5000XLIX438, SURT7500XLJ-2TF4, SURTA2000RMXL2U, SURTD3000RMXLT, SURTD3000RMXLT-1TF5, SURTD5000RMXLT, SURTD5000RMXLT-1TF5
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £197.72 |
APC 1U Vertical Cable Organiser | In Stock | £119.92 |
APC 1U Horizontal Cable Organiser | In Stock | £53.60 |
APC Netshelter heavy duty shelf | In Stock | £137.58 |
APC - rack cable guide - 1U | In Stock | £48.46 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £286.90 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £311.94 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £271.25 |
APC Cable Managers (Qty 10) | In Stock | £34.52 |
APC 2G Power distribution strip | In Stock | £622.55 |
APC Rack PDU 2G METERED ZEROU | In Stock | £671.97 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £962.24 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £953.12 |
APC 19" Rack LCD Console | In Stock | £1,344.09 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £76.76 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,463.26 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £64.11 |
APC 1U Blanking Panel Kit | In Stock | £33.82 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £54.39 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,602.33 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £614.64 |
APC Metered Rack PDU | In Stock | £817.13 |
APC Smart-UPS 1500VA RM 230V w/Network Card | In Stock | £1,127.20 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £731.73 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £263.29 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,023.33 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £59.34 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,129.15 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £668.72 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,217.48 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £155.82 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £80.21 |
APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V | In Stock | £2,141.29 |
