APC Switched Rack Power Distribution Units (PDUs) enable advanced, user-customizable power control and active monitoring. Remote outlet level controls allow power on/off functionality for power recycling to remotely reboot equipment and restrict unauthorized use of individual outlets. Power sequencing delays allow users to define the order in which to power up or down attached equipment. Avoid circuit overload during power recovery and extend uptime of critical equipment by prioritizing the load shedding. Current metering provides real-time remote monitoring of connected loads. Switched Rack PDUs include real power monitoring, a temperature/humidity sensor port, locking IEC receptacles, and low profile circuit breakers. User-defined alarms warn of potential circuit overloads before critical IT failures occur. Users can access, configure, and control Switched Rack PDUs through secure Web, SNMP, or Telnet Interfaces.
Metering-by-Outlet capability
Individual outlet level power metering provides a more granular view of the power distributed to equipment within the enclosure. It also provides the ability to analyze component power trends and perform capacity planning.
- APC Switched Rack PDU 2G Zero U - power distribution unit
- Power distribution unit - rack-mountable
- Rack Size
- 0U
- 8.2 kg
- Input Voltage
- AC 200/208/230 V
- Output Voltage
- AC 230 V
- Input Connectors
- 1 x power IEC 60309
- Output connectors
- 3 x power IEC 60320 C19 , 21 x power IEC 60320 C13
- Networking
- Ethernet 10/100, RS-232
- Remote Management Protocol
- SNMP, Telnet, HTTP
- Black
- 5.6 cm x 5.1 cm x 183 cm
- 2-year warranty
- Designed For
- P/N: AR3357X674, SCL500RMI1UC, SMX1000C, SMX1500RM2UC, SMX1500RMNCUS, SMX1500RMUS, SMX2000LVNCUS, SMX2000LVUS, SMX2200RMLVUS, SMX3000HVTUS, SMX3000LVNCUS, SMX3000LVUS, SMX3000RMLVUS, SMX3KRMLVNCUS, SMX750CNC, SMX750US, SRT1000RMXLI, SRT1000RMXLI-NC, SRT10RMXLIX806, SRT5KRMXLTUS, SRT5KRMXLW-TW
- Height (Rack Units)
- 0U
- Black
- Input Voltage
- AC 200/208/230 V
- Input Voltage Range
- AC 220 - 240 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V
- Max Electric Current
- 32 A
- Remote Management Interface
- 1 x management (Ethernet) - RJ-45 , 1 x management (RS-232)
- Cables Included
- Power cable - external - 3 m , Serial cable - external
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, overload protection
- EN 61000-3-2, VDE, EN 61000-3-3, EN55024, EN55022 Class A, RoHS, REACH
- Limited warranty - 2 years
- -5 °C
- 45 °C
- 5 - 95%
- 5.6 cm
- 5.1 cm
- 183 cm
- 8.2 kg
- Shipping Width
- 16.2 cm
- Shipping Depth
- 11.8 cm
- Shipping Height
- 204 cm
- Shipping Weight
- 10.5 kg
- Designed For
- P/N: AP5607, AP7950B, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR3100G, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3105, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140G, AR3140W, AR3150SP, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3180G, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, NBES0302, NBPD0160A, NBPD0171, NBPD0172, NBPD0180, NBWL0355A, NBWL0356A, SCL500RMI1UC, SMC1000, SMC1000-2U, SMC1000-BR, SMC1000I, SMC1000I-2U, SMC1000I-2UC, SMC1000I-BR, SMC1000IC, SMC1500, SMC15002U-BR, SMC1500-BR, SMC1500I, SMC1500I-2U, SMC1500I2U-BR, SMC1500I-2UC, SMC1500I-BR, SMC1500IC, SMC2000I-2U, SMC3000RMI2U, SMT1500RM1U, SMT1500RM2U, SMT1500RMI1U, SMT2200RM2UC, SMT3000I2U-BR, SMT3000RM2UC, SMT3000RMT2U, SMX1000C, SMX1000US, SMX1500RM2UC, SMX1500RMNCUS, SMX1500RMUS, SMX2000LV, SMX2000LVNC, SMX2000LVNCUS, SMX2000LVUS, SMX2200HV, SMX2200HVNC, SMX2200R2HVNC, SMX2200RMHV2U, SMX2200RMLVUS, SMX3000HV, SMX3000HV-BR, SMX3000HVNC, SMX3000HVT, SMX3000HVTUS, SMX3000LV, SMX3000LV2U-BR, SMX3000LVNC, SMX3000LVNCUS, SMX3000LVUS, SMX3000RMHV2U, SMX3000RMHV2UNC, SMX3000RMLVUS, SMX3KRMLVNCUS, SMX750CNC, SMX750-NMC, SMX750US, SRT1000RMXLA, SRT1000RMXLA-NC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT10KRMXLI, SRT10RMXLIX806, SRT1500RMXLA, SRT1500RMXLA-NC, SRT5KRMXLT, SRT5KRMXLT-IEC, SRT5KRMXLTUS, SRT5KRMXLW-HW, SRT5KRMXLW-TW, SRT6KRMXLI, SRT6KRMXLT, SRT6KRMXLT-IEC, SRT8KRMXLI, SRT8KRMXLT, SRT8KRMXLT-IEC, SURT3000XLI-ET, SURT5000XLIX438, SYA12K16RMICH, SYA16K16RMICH, SYA8K16RMICH, SYAF16KRMICH
APC Temperature and Humidity Sensor | In Stock | £133.03 |
APC Power Cord Locking C19 to C20 3.0m | In Stock | £70.43 |
APC Power Cord Kit (6 ea) Locking C19 to C20 1.2m | In Stock | £154.75 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £59.45 |
APC Power Cable (pack of 6) 1.22m | In Stock | £90.64 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £133.14 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £105.31 |
