Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Battery failure notification provides early-warning fault analysis on batteries enabling timely preventive maintenance. Reserves power capacity and run time for connected equipment that require battery back-up while providing surge only protection for less critical equipment.
Cold-start capable provides temporary battery power when the utility power is out. Hot-swappable batteries ensure clean, uninterrupted power to protected equipment while batteries are being replaced. Dataline surge protection provides protection of connected equipment from power surges on the data lines.
Includes: CD with software, Qty 2 - Detachable 2.0 m IEC power cords, Telephone Cable, USB cable, User Manual, Warranty card
User-replaceable batteries
Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR) -
Audible alarms
Provides notification of changing utility power and UPS power conditions -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced -
Intelligent battery management
Maximizes battery performance, life, and reliability through intelligent, precision charging -
Cold-start capable
Provides temporary battery power when the utility power is out -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection -
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Battery replacement without tools
Enables fast battery replacement, lowering Mean Time to Repair (MTTR) -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment -
LCD graphics display
Text and mimic diagrams that display modes of operation, system parameters and alarms -
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
Battery-protected and surge-only outlets
Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment -
Boost and Trim Automatic Voltage Regulation (AVR)
Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models) -
Resettable circuit breaker
Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs) -
Serial connectivity
Provides management of the UPS via a serial port -
Provides protection of connected equipment from power surges on the data lines -
Disconnected battery notification
Warns when a battery is not available to provide backup power -
Transformer-block spaced outlets
Protect equipment with input transformer blocks without blocking access to other receptacles -
USB connectivity
Provides management of the UPS via a USB port (not available on all models) -
Adjustable voltage-transfer points
Maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation -
Adjustable voltage sensitivity
Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications -
Power-saving outlets
Automatically cuts power to idle equipment to conserve electricity -
Telephone dataline surge protection
Provides protection of connected equipment from power surges traveling on telephone lines
- APC Back-UPS Pro 1200 - UPS - 720 Watt - 1200 VA
- UPS - external
- 11.6 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 720 Watt / 1200 VA
- Input Connectors
- Power IEC 60320 C14
- Output connectors
- 5 x power IEC 60320 C13 (UPS and surge) , 5 x power IEC 60320 C13 (surge)
- Battery
- Lead Acid
- Run Time (Up To)
- 7.6 min at full load
- Networking
- USB
- Black
- 11.2 cm x 38.2 cm x 30.2 cm
- 2-year warranty (European Union - 3 years)
- UPS - external
- Black
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 186 - 284 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V 50/60 Hz
- Power Capacity
- Dataline Surge Protection
- Network - RJ-45 , Phone line - RJ-11
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 445 Joules
- Technology
- Lead Acid
- Run Time (Up To)
- 7.6 min at full load , 19.9 min at half load
- Recharge Time
- 8 hours
- Remote Management Interface
- USB
- 1 x management (USB)
- Cables Included
- USB cable - external
- Audible alarm, LCD display
- TUV, GOST, GS, RoHS, A-Tick
- Limited warranty - 2 years , European Union: limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 45 dBA
- 11.2 cm
- 38.2 cm
- 30.2 cm
- 11.6 kg
- Shipping Width
- 23.8 cm
- Shipping Depth
- 48.8 cm
- Shipping Height
- 38.7 cm
- Shipping Weight
- 13.2 kg
APC Service Pack 1 Year Warranty Extension | In Stock | £42.84 |
APC Service Pack 3 Year Warranty Extension | In Stock | £97.06 |
