APC Performance SurgeArrest surge suppressor-AC 230 V - 8 Output Connectors
Quicklinx: 43PHWS00 Mfr#: PF8VNT3-UK
Lightning and power surges can permanently ruin your electronic equipment. Changes in voltage cause lockups and loss of work. This unit will protect your equipment from the threat of bad power. The Performance SurgeArrest series provides maximum protection for high performance multimedia computers and electronic equipment.
  • Building Wiring Fault Indicator
    This LED informs users of potentially dangerous wiring problems in the wall circuit
  • Manual disconnect switch
    Enables the surge supressor to be de-energized for service without disconnecting the protected load
  • Right Angle Plug
    Plug angle allows for equipment and furniture to be placed closer to the wall than with a standard power cord. Reduces cord stress too
  • Always on Outlets
    8 outlet models offer dedicated space to accommodate wide transformer blocks without covering adjoining outlets and 2 always on outlets. You can plug 8 power cords including 3 transformers at the same time. In case you have equipment that has to stay on all the time, such as fax machine, you can plug it in always on outlets. The equipment will be protected and will have power supply even when the unit is switched off
APC Performance SurgeArrest - surge protector
Surge protector - external
1.3 kg
United Kingdom
Input Voltage
AC 230 V
Input Connectors
1 x power BS 1363
Output connectors
8 x power BS 1363
Charcoal
12.2 cm x 4.2 cm x 37.2 cm
Charcoal
United Kingdom
Input Voltage
AC 230 V
Frequency Required
50/60 Hz
Input Connectors
1 x power BS 1363
8 x power BS 1363
Max Electric Current
13 A
Dataline Surge Protection
Phone line - RJ-11 - 1 input line / 2 output lines , Cable TV - RCA , Network - RJ-45
Surge Suppression
Surge Energy Rating
2525 Joules
EMI/RFI Noise Filtration
70 dB
Circuit Protection
Circuit breaker
Power cable - integrated - 3 m , 2 x phone cable - external - 1.8 m , Coaxial RF cable - external - 0.6 m , Network cable - external - 1.8 m
UL 1449
Limited warranty - lifetime
0 - 95%
12.2 cm
4.2 cm
37.2 cm
1.3 kg
Resources
The following resources are available for the APC Performance SurgeArrest surge suppressor-AC 230 V - 8 Output Connectors
